  • 18
manj_dosanjh
Message 1 of 5
Speed Issues After Upgrading
Hi, I recently upgraded to the full package. My speed went from 350 to 500. I used to get 2G – 150/200 and 5G - 300/350 – Wired 300/350. I know get 2G – 30/50 and 5G – 200/250 – Wired 200/275. Why on earth after upgrading has my speed got less??? I tried all the usual stuff, off and on, full reset, extender sent to me also and usual signals sent. Spoke to a horrendous your over the phone tech… to be told… wait for it… there is nothing I can do about it and a tech will not be sent… that’s all his diagnostics would allow to do… what the hell kind of service is that! Please help!
  • 1.5K
  • 81
  • 102
Message 2 of 5
Re: Speed Issues After Upgrading
Hi manj_dosanjh,
Thanks for your post, and sorry to hear you've been having some issues with the speeds since the upgrade.
I've run a health check on the equipment and need a few more details from you, I've sent you over a private message (little purple envelope, top right hand corner)
Get back to me when you can,
Alex_Rm
  • 18
manj_dosanjh
Message 3 of 5
Thanks - I have done.
  • 27
johnboy1948
Message 4 of 5
Hi ,
I am in the same position as you since I upgraded and again like you when you speak to VM they cant help and it seems there advice is to hang on there it will improve , so the only conclusion you can make is that the roll out to 500 Mbps was premature and there promises as of now cant be kept at this point in time.
  • 18
manj_dosanjh
Message 5 of 5
But it doesn't make sense does it? The worst case is it stays the same right? But to go backwards makes no sense?!?
