donnylad82
Message 1 of 5
Speed Issue HELP! Please
Hi all
Hope someone knows what's going on here at all, as I'm lost with it now. I'm running Hub3 as router with Deco M4 on the M600 package. I get ethernet speed test of 190-250mbps (never the same) - the V6 box gets network Status of 5GHz 82% wifi signal with connection speed of 785mbps - Wifi 5GHz speed test gets 165-215mbps. I'm lost big time.
Below are all the logs, what the simple reason to why I ain't even getting a decent speed & how can I fix it at all please...
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
1.4
40
256 qam
25
2
267000000
2.7
40
256 qam
17
3
275000000
0.7
38
256 qam
18
4
283000000
-0.5
40
256 qam
19
5
291000000
1
38
256 qam
20
6
299000000
2.7
40
256 qam
21
7
307000000
0.5
38
256 qam
22
8
315000000
-0.5
40
256 qam
23
9
323000000
0.4
40
256 qam
24
10
339000000
1.2
40
256 qam
26
11
347000000
0.7
40
256 qam
27
12
355000000
0.7
40
256 qam
28
13
363000000
2
40
256 qam
29
14
371000000
2.9
40
256 qam
30
15
379000000
0.5
38
256 qam
31
16
387000000
-0.5
40
256 qam
32
17
395000000
0.9
38
256 qam
33
18
403000000
2.4
40
256 qam
34
19
411000000
1
40
256 qam
35
20
419000000
0.2
40
256 qam
36
21
427000000
1.7
38
256 qam
37
22
435000000
2.7
40
256 qam
38
23
443000000
0
38
256 qam
39
24
451000000
-1.7
38
256 qam
40
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.9
1461
2
2
Locked
40.9
2583
277
3
Locked
38.9
821
0
4
Locked
40.3
633
0
5
Locked
38.9
421
0
6
Locked
40.3
620
40
7
Locked
38.9
761
0
8
Locked
40.3
974
0
9
Locked
40.3
2181
0
10
Locked
40.3
854
0
11
Locked
40.3
372
0
12
Locked
40.3
326
0
13
Locked
40.3
251
0
14
Locked
40.3
200
0
15
Locked
38.9
308
0
16
Locked
40.3
386
0
17
Locked
38.9
767
0
18
Locked
40.9
927
0
19
Locked
40.3
399
0
20
Locked
40.3
206
0
21
Locked
38.9
283
14
22
Locked
40.3
422
0
23
Locked
38.9
523
0
24
Locked
38.9
467
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
40.8
5120
64 qam
9
2
46200000
42.3
5120
64 qam
3
3
39400000
41.8
5120
64 qam
7
4
25800000
40.3
5120
64 qam
10
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
3
0
2
ATDMA
0
0
1
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
1
0
Time
Priority
Description
11/02/2021 17:32:47
critical
11/02/2021 05:01:18
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/02/2021 17:33:47
critical
03/02/2021 13:23:2
Error
02/02/2021 10:03:11
critical
31/01/2021 01:23:1
Error
30/01/2021 15:00:3
critical
27/01/2021 13:23:1
Error
24/01/2021 12:40:41
critical
20/01/2021 12:40:49
Error
17/01/2021 21:54:41
critical
17/01/2021 00:40:49
Error
14/01/2021 15:19:4
critical
13/01/2021 20:32:38
Error
01/01/1970 00:01:41
critical
11/01/2021 01:13:2
notice
SW download Successful - Via NMS
11/01/2021 01:10:13
notice
SW Download INIT - Via NMS
09/01/2021 15:49:6
Error
07/01/2021 01:03:32
critical
06/01/2021 03:49:7
Error
  • 20.49K
  • 2.18K
  • 3.61K
Message 2 of 5
Re: Speed Issue HELP! Please
Is there any reason why you aren't running with the Hub in Modem mode with the Deco's doing the routing and wifi ? That one of the main reasons for using the Deco's on VM.
donnylad82
Message 3 of 5
Sorry, I should of put the hub is being used in modern mode not as router.
Andruser
  • 5.52K
  • 970
  • 2.28K
Message 4 of 5
The 4.6 dBmV power range across downstream channels looks a touch too wide for stability in my view, and there's breakthrough uncorrected (post-RS) errors on several channels.    As a short term expedient, turn the hub to router mode (which will clear the error counts, unfortunately) turn hub wifi off, and put the Deco in access point mode (easily done via the app).  Let that run for 24 hours, repost the hub status data.  If power levels remain wide and the errors return we can ask staff to take a look
donnylad82
Message 5 of 5
New data after changes, still showing issues????
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
1.2
40
256 qam
25
2
267000000
2.5
40
256 qam
17
3
275000000
0.5
38
256 qam
18
4
283000000
-0.7
40
256 qam
19
5
291000000
0.7
38
256 qam
20
6
299000000
2.5
40
256 qam
21
7
307000000
0.4
38
256 qam
22
8
315000000
-0.7
40
256 qam
23
9
323000000
0.2
40
256 qam
24
10
339000000
1
40
256 qam
26
11
347000000
0.5
40
256 qam
27
12
355000000
0.4
40
256 qam
28
13
363000000
1.5
40
256 qam
29
14
371000000
2.5
40
256 qam
30
15
379000000
0.2
38
256 qam
31
16
387000000
-1
40
256 qam
32
17
395000000
0.4
38
256 qam
33
18
403000000
1.7
40
256 qam
34
19
411000000
0.5
40
256 qam
35
20
419000000
-0.5
40
256 qam
36
21
427000000
1
38
256 qam
37
22
435000000
1.9
40
256 qam
38
23
443000000
-0.7
38
256 qam
39
24
451000000
-2.5
38
256 qam
40
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
1956
21
2
Locked
40.9
3437
436
3
Locked
38.9
1432
0
4
Locked
40.3
1823
0
5
Locked
38.9
915
0
6
Locked
40.3
847
0
7
Locked
38.9
1792
1
8
Locked
40.3
2098
0
9
Locked
40.3
3055
34
10
Locked
40.3
1069
15
11
Locked
40.3
687
0
12
Locked
40.3
683
0
13
Locked
40.3
478
0
14
Locked
40.3
376
0
15
Locked
38.9
731
0
16
Locked
40.3
859
7
17
Locked
38.9
1131
9
18
Locked
40.9
1107
0
19
Locked
40.3
647
14
20
Locked
40.3
610
20
21
Locked
38.9
604
0
22
Locked
40.3
575
0
23
Locked
38.9
1100
15
24
Locked
38.6
1022
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
41.3
5120
64 qam
9
2
46200000
42.8
5120
64 qam
3
3
39400000
42.3
5120
64 qam
7
4
25800000
40.8
5120
64 qam
10
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
3
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
5
0
4
ATDMA
0
0
2
0
Time
Priority
Description
22/02/2021 16:19:21
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2021 15:04:19
critical
18/02/2021 20:23:10
Error
16/02/2021 19:25:41
critical
15/02/2021 22:45:4
Error
13/02/2021 16:35:6
notice
01/01/1970 00:01:39
critical
13/02/2021 15:46:56
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/02/2021 17:32:47
critical
11/02/2021 05:01:18
Error
03/02/2021 17:33:47
critical
03/02/2021 13:23:2
Error
02/02/2021 10:03:11
critical
31/01/2021 01:23:1
Error
30/01/2021 15:00:3
critical
27/01/2021 13:23:1
Error
24/01/2021 12:40:41
critical
20/01/2021 12:40:49
Error
17/01/2021 21:54:41
critical
17/01/2021 00:40:49
Error
