Stythinator
  • 3.75K
  • 91
  • 339
Problem sorter
Message 1 of 7
Speed Fluctuating
Hello,
Can someone from Virgin Media please look at me Connection
Download and Upload speeds have been fluctuating badly in the last week or so via RJ45 1GB.
Having to keep restarting the Router all the time Is there any work going on in the Area?
The Upload also seems to be stuck on 20mbps or below.
12030000006.838256 qam9
21390000007.538256 qam1
31470000007.138256 qam2
4155000000738256 qam3
51630000006.838256 qam4
6171000000738256 qam5
7179000000738256 qam6
8187000000738256 qam7
9195000000738256 qam8
102110000006.438256 qam10
11219000000638256 qam11
122270000005.538256 qam12
13235000000538256 qam13
142430000003.738256 qam14
152510000004.538256 qam15
162590000004.938256 qam16
172670000004.938256 qam17
182750000005.838256 qam18
192830000006.938256 qam19
202910000007.638256 qam20
212990000007.538256 qam21
223070000007.638256 qam22
233150000007.540256 qam23
243230000007.538256 qam24
1Locked38.950
2Locked38.660
3Locked38.660
4Locked38.650
5Locked38.600
6Locked38.950
7Locked38.950
8Locked38.650
9Locked38.960
10Locked38.660
11Locked38.940
12Locked38.650
13Locked38.9120
14Locked38.600
15Locked38.640
16Locked38.660
17Locked38.600
18Locked38.650
19Locked38.650
20Locked38.900
21Locked38.960
22Locked38.940
23Locked40.350
24Locked38.6140
12579994141.5512032 qam6
23940000041.8512064 qam4
34620000041.8512064 qam3
43260000041.5512064 qam5
3ATDMA0000
4ATDMA0000
Stythinator
  • 3.75K
  • 91
  • 339
Problem sorter
Message 2 of 7
Re: Speed Fluctuating
14/01/2021 01:45:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 15:23:49ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 21:48:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 13:09:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 13:09:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 11:04:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 19:54:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 17:31:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 16:40:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 17:15:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 17:35:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 04:47:18ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 11:39:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 16:47:17ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 20:43:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 05:14:48ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 23:05:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 14:23:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 00:08:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 19:57:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Stythinator
  • 3.75K
  • 91
  • 339
Problem sorter
Message 3 of 7
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg
SFID150796
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID150795
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 7
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 7
This was a bit confusing in your initial post ...
"Download and Upload speeds have been fluctuating badly in the last week or so via RJ45 1GB."
At first I thought you were on the 1Gbs service but your Configuration data shows that you are on the 500Mbs service and the Hub data is for a Hub 3 not a Hub 4.
SFID150796
Min Traffic Rate0
SFID150795
Min Traffic Rate0
Stythinator
  • 3.75K
  • 91
  • 339
Problem sorter
Message 6 of 7
Firstly i put "RJ45 1GB" that would tell anyone who is even tech savy that i was saying hardwired and connected at 1GB rather than 10/100. This is why i have asked Virgin to look at my Connection.
Yes you are correct 500/35 connection.
Latency
19.2 ms
Jitter
3.95 ms
Download
289 Mbps
Upload
10.1 Mbps
Stythinator
  • 3.75K
  • 91
  • 339
Problem sorter
Message 7 of 7
https://www.thinkbroadband.com/broadband/monitoring/quality/share/9a06aa20c539806ead7ff63bb882cadff799fac8
