WreckZ
  • 36
Message 1 of 13
Speed Capped?
Ok, so I'm not sure when it started but my download speed seems to be capped. Possibly since the outages earlier in the week where large numbers lost their internet service three or four times during the evening.
I'm paying for the 512Mbps service, and it's not supposed to drop below 200Mbps.
This is all I get at the moment on a wired connection:-
I have run the 'Test' a number of times and I keep getting this result:-
I understand that these are unprecedented times, and loads on the Internet are close to peak Holiday loads for much of the time, but the lack of a proactive communication system with customers is quite frankly astonishing from a communications company. One wonders if they grasp the meaning of the word.
One cannot contact the call centres, because the Company decided to base them off-shore. In a country that is locked down and workers cannot leave home.
So it is something of an oxymoron to not be able to communicate with a communications company.
I will be monitoring my connection speeds daily, and if the situation persists I will be expecting a refund or significant discount on my broadband connection.
Right then, so now to contact Offcom and register a complaint.
JR
-tony-
  • 16.54K
  • 1.31K
  • 3.91K
Message 2 of 13
Re: Speed Capped?
is that a test via wifi - if so what do you get wired - will leave that but i think it is wired
so try a reboot and then a reset
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
WreckZ
  • 36
Message 3 of 13
Re: Speed Capped?
JR
TheChairman
  • 351
  • 23
Up to speed
Message 4 of 13
Re: Speed Capped?
Can you post the router stats as requested.
Also on speedtest.net do single and mulit thread test.
gary_dexter
  • 30.57K
  • 1.89K
  • 4.06K
Message 5 of 13
Re: Speed Capped?
So are you asking for help here or just venting?
WreckZ
  • 36
Message 6 of 13
Re: Speed Capped?
JR
-tony-
  • 16.54K
  • 1.31K
  • 3.91K
Message 7 of 13
Re: Speed Capped?
levels are good - have you done a reboot and if that does not help a reset - also run a speedtest in modem mode
Tony
WreckZ
  • 36
Message 8 of 13
Re: Speed Capped?
Hmmmm, not entirely happy.
I think it is sorted to a degree, but I've got it running in Router mode now, and speed is back to normal.
I was having big issues switching from Modem to Router mode, and back. My preferred mode is modem mode as I have a Cisco router I'm using to control network traffic and QoS.
Going to try switching back later when fewer users on the network.
JR
gary_dexter
  • 30.57K
  • 1.89K
  • 4.06K
Message 9 of 13
Re: Speed Capped?
So router mode is fine?
And modem mode with your Cisco router has issues?
WreckZ
  • 36
Message 10 of 13
Re: Speed Capped?
Yes Router mode is fine.
I tried to switch back to Modem mode but there was some sort of issue and it took multiple power cycles and resets to get the Superhub to come back up.
As I posted, I'm going to try to switch back to modem mode later because the RV180 has features that the SuperHub doesn't when it comes to routing.
Yes I'm aware that it may be the Cisco RV180 that has the issue, but until I switch back to Modem mode it is difficult to test.
However, when I tried to run the test off the VirginMedia website it recorded issues, and so I believe the Hub may have developed an issue in modem mode.
JR
