  • 3.56K
  • 196
  • 545
Community elder
Message 11 of 26
Re: Speed! 200 my arse
If your devices are connecting on 2.4 GHz you will not get higher speeds. And remember that if several devices are connected they will share the speed between them.
There are lots of things you can do to improve the WiFi.  Read through the help files
  • 15
Message 12 of 26
I've tried! Turned everything off apart from the laptop at 1am and the wifi speed on 5ghz is still slower than it was!
  • 3.56K
  • 196
  • 545
Community elder
Message 13 of 26
Well this is nothing to do with the broadband service, because you have tested that with a wired connection. Are you sure that gets you 200Mb?
You will need to read up on the WiFi help files. It can't be changed remotely.
  • 20.96K
  • 1.13K
  • 2.7K
Message 14 of 26
If your Deco isn’t putting out full speeds have your tried removing it from the equation?
  • 15
Message 15 of 26
We're in Area 20 which is over subscribed so my 200 that I pay for is more like 80 so I might be better off looking at paying half the money for 50 mbps 😞
  • 15
Message 16 of 26
It's 3 meters away
  • 3.56K
  • 196
  • 545
Community elder
Message 17 of 26
You said in #7 that you get 200 with a wired connection, so you are getting what you pay for.
WiFi is your responsibility.
Area is an administrative area not a technical one. I'm in area 20 too and like you I get just what I pay for.
Bye for now.
  • 20.96K
  • 1.13K
  • 2.7K
Message 18 of 26
You need to reoptimise your Wi-Fi setup then.
If you get full speeds when wired, I.e full speed delivered to your hub, then there’s nothing wrong with your connection.
  • 15
Message 19 of 26
How would I do that? Is there a link!
  • 20.96K
  • 1.13K
  • 2.7K
Message 20 of 26
Re: Speed! 200 my *Bleep*
First things first I would look at the deco.
What system is it? How many discs?
