Kayesc
  • 17
Message 1 of 27
Speed! 200 my *Bleep*
We started with Fibre 50 and it always run at 52mbps. Been upgraded twice, 100 then 200 and the speed has got worst since...???
Tags (1)
jpeg1
  • 4.54K
  • 254
  • 729
Superstar
Message 2 of 27
Re: Speed! 200 my *Bleep*
What devices are you using and how are they connected to the Hub?
kizi
  • 210
  • 41
  • 38
Message 3 of 27
you can try adjusting the channel settings in the hub to see if you can get a bit speed I can help you if you need me to
gary_dexter
  • 30.65K
  • 1.9K
  • 4.08K
Message 4 of 27
Worse in what way?
What devices are you testing with and over wireless or a wired connection?
Kayesc
  • 17
Message 5 of 27
Re: Speed! 200 my arse
Speed has gone down! Tried most things but now get 30-50mbps where as it used to be 52 all the time.
jpeg1
  • 4.54K
  • 254
  • 729
Superstar
Message 6 of 27
We can't help if you don't answer the questions!
Kayesc
  • 17
Message 7 of 27
Everything is the same as it was when we had fiber 50, we now have 200 and it is slower than it was before. If you plug directly into the router you might get 200 but whats the point of have 200 if you get less on the wifi then what we had before on 50!
jpeg1
  • 4.54K
  • 254
  • 729
Superstar
Message 8 of 27
So you have a WiFi problem, not a broadband problem.
Have you followed the Help links to improve your WiFi?
Which WiFi bands do you use? You will need to use 5GHz if you want the full 200 speed.
Kayesc
  • 17
Message 9 of 27
We use both bands! It is also a different router since we had fiber 50 and the wifi speed 50mm from the router is still slow
Kayesc
  • 17
Message 10 of 27
I have a TP-Link Deco pluged in for my wifi and the speed is still slow
