Solid red light
charliehale
My hun has a solid red light but the internet seems to be working fine. My tv keeps flicking on and off quickly every minute or so. It isn’t the TV itself as I am able to watch apps via the TV and they are working fine.
6 REPLIES 6
charliehale
*hub
Hi there @charliehale
Thank you so much for your post and welcome to the community forums, it's great to have you on the team.
I am so sorry to hear that you have faced this issue with your Hub! Can I just check is the hub in an open and well ventilated area?
Are you able to perform a full factory reset? To do this push a pen etc into the rest hole and hold it in for 20 seconds. Does this change the light at all?
Thank you.
Yes it is in an open well ventilated area and doesn’t feel hot.
unfortunately the reset has not changed anything, it flashed red initially but is now solid red again.
Sounds like the Hub needs to be replaced as it looks like the overheat LED warning is faulty.   VM should arrange this in due course.
Hi charliehale, thanks for the message and welcome to the forums.
I am sorry to hear that the hub has a red light and will send you a private message so that this can be looked into.
Kind regards, Chris.
Hi All! 👋 Just returning to this thread to keep it updated.
Thank you to Charliehale for PMing with us 📩. Following some troubleshooting support the red light is still stuck on the hub and so an appointment has been booked to investigate further and replace the hub if needed. You can view and manage appointments via your My Virgin Media account here 👉 virg.in/myVM
I hope the appointment goes well! Please do get back in touch if you still have issues and need further support afterwards, and we will be happy to help!
Wishing you all the best. 🌞
Molly
