  • 8
Message 1 of 15
Slowest speed!!
Usually on average have around 100mbps but as of yesterday I've been struggling to even hit 2mbps!!!!! Have been on the phone to virgin and had no outcome or help as they think it's fine. Done all usual resets and still nothing. Pleeeeease help!
Tags (3)
  • 20.96K
  • 1.13K
  • 2.7K
Message 2 of 15
Re: Slowest speed!!
Wireless or wired speeds?
  • 8
Message 3 of 15
Re: Slowest speed!!
Sorry mate total newbie to this. It's all wireless speeds. My phone, ipads, xbox etc. Hope that helps
  • 20.96K
  • 1.13K
  • 2.7K
Message 4 of 15
Re: Slowest speed!!
You need to speedtest when wired (and not via a console).
Wireless speeds and connectivity aren’t guaranteed
  • 8
Message 5 of 15
Re: Slowest speed!!
I'm doing speed tests via my phone (just some websites all showing its below 2mbps), the xbox is showing the same speed, and I can't even watch a video on amy device I've got mate.
  • 20.96K
  • 1.13K
  • 2.7K
Message 6 of 15
Re: Slowest speed!!
The same answer given above applies.
You need to speedtest when wired (not wireless) and not via a console.
  • 8
Message 7 of 15
Re: Slowest speed!!
Okey doke. What will that achieve that's not already been done? As I said I'm a newbie so not sure what to be looking out for
  • 20.96K
  • 1.13K
  • 2.7K
Message 8 of 15
Re: Slowest speed!!
Per the second part of my second answer:
”Wireless speeds and connectivity aren’t guaranteed”
To ascertain that the hub is getting its full speeds you need to test with a wired connection.
  • 8
Message 9 of 15
Re: Slowest speed!!
Would plugging in my laptop using an ethernet do the trick?
  • 20.96K
  • 1.13K
  • 2.7K
Message 10 of 15
Re: Slowest speed!!
Yes. That would be using a wired connection.
