Jac_williams
  • 5
Message 1 of 8
Slower than expected speed for M500
Hi there,
I've been through the guidance and done a hard reset and also did the service checker at the top of the page (all was fine in my area etc). I currently have around 80/90 mbps download speed and around 30 mbps for upload. The highest I have seen so far is 160 mbps and we have the M500 package.
I have attached the logs below. Could someone please advise? thanks in advance.
Jac
Jac_williams
  • 5
Message 2 of 8
Re: Slower than expected speed for M500
Downstream
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
1.2
38
256 qam
1
2
147000000
1.5
38
256 qam
2
3
155000000
1.4
38
256 qam
3
4
163000000
1.2
38
256 qam
4
5
171000000
0.4
38
256 qam
5
6
179000000
-0.2
38
256 qam
6
7
187000000
-0.2
37
256 qam
7
8
195000000
0
38
256 qam
8
9
203000000
0
38
256 qam
9
10
211000000
0.5
37
256 qam
10
11
219000000
0.2
38
256 qam
11
12
227000000
-0.2
37
256 qam
12
13
235000000
-0.2
37
256 qam
13
14
243000000
0
37
256 qam
14
15
251000000
-0.5
37
256 qam
15
16
259000000
-1.2
37
256 qam
16
17
267000000
-0.7
37
256 qam
17
18
275000000
-0.7
37
256 qam
18
19
283000000
-1.5
37
256 qam
19
20
291000000
-2.2
37
256 qam
20
21
299000000
-1.4
37
256 qam
21
22
307000000
-1.5
37
256 qam
22
23
315000000
-1.7
37
256 qam
23
24
323000000
-0.7
37
256 qam
24
Jac_williams
  • 5
Message 3 of 8
Upstream
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
51
5120
64 qam
5
2
39400000
51
5120
64 qam
4
3
46200000
51
5120
64 qam
3
4
53700000
51
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
2
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
1
0
Jac_williams
  • 5
Message 4 of 8
30/12/2020 15:16:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 15:10:32Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 13:56:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 08:02:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 22:15:0ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 20:16:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 15:18:49ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 12:12:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 10:02:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 15:12:56ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 14:44:8noticeSW download Successful - Via Config file
22/12/2020 14:42:15noticeSW Download INIT - Via Config file
01/01/1970 00:02:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/12/2020 19:39:26noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/12/2020 19:31:11noticeSW download Successful - Via Config file
15/12/2020 19:25:32noticeSW Download INIT - Via Config file
01/01/1970 00:03:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 12:02:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 8
Your Upstream Power Levels are all maxed out.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
51
5120
64 qam
5
2
39400000
51
5120
64 qam
4
3
46200000
51
5120
64 qam
3
4
53700000
51
5120
64 qam
2
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 8
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Jac_williams
  • 5
Message 7 of 8
Thank you. I'm trying to find a contact number to ring them tomorrow but I'm struggling. Do you know what the correct number is?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 8
150 from Virgin landline - as long as you can put up with the canned music.
0345 454 1111 from any other UK  phone - as long as you can put up with the canned music.
