mickywaz
  • 8
Message 1 of 8
Slower speeds with Hub4
Guy I'm in a bit of a pickle. Have had virgin 500mb for a few months. Running fine. Got between 500-600 constantly. Have upgraded to virgin 1gb and got the new Hub4. My speeds are now horrible compared to what they used to be. The odd time I get 945 on speed test. That lasts sometime up to a few hours then my speeds tank. The other morning I done a speed test and I was getting 50mb. Have had virgin out this morning and they can't find a fault. Sammobile speed test shows that I'm getting the full speed to the hub but then awful speeds to my computer that's connected by ethernet. I have now tried 4 cat6 cables to no avail. I'm wondering at this point if something on my pc could be causing the issue. Any help would be appreciated.Screenshot 2021-10-27 100212.png
  • 6.09K
  • 512
  • 1.57K
Message 2 of 8
Re: Slower speeds with Hub4
Usual request.  Please post the Network Log, Downstream and Upstream logs and Pre and PostRS errors for comment.  Do not use screenshots, just copy and paste the text.
Also setup a BQM to monitor your circuit.   www.thinkbroadband.com/ping
Try a speedtest from the PC in safe mode with networking in case software on the PC is causing problems.
mickywaz
  • 8
Message 3 of 8
Thanks for the reply. I can't do what you've asked just yet. But I've put the pc in safemode with networking and I'm constantly getting max speed. Something must me on my pc to be interfering with it.
  • 14.12K
  • 1.89K
  • 4.34K
Message 4 of 8
Hi @mickywaz
It might be your anti virus.
I kept getting slow speeds when using Avast - I turned  it off for an hour as an experiment and the speed improved.
I then uninstalled Avast and just use the built in Windows Anti Virus and Security
Dave
mickywaz
  • 8
Message 5 of 8
Thanks for the reply. I only have the windows antivirus installed. I disabled it to check and still have the problem. I'm running out of ideas.
Lee_R
  • 6.26K
  • 289
  • 651
Message 6 of 8
Hi mickywaz thanks for posting and welcome back to our community.
Sorry to hear that you're having slow speeds.  Have you gotten to the bottom of your issue since posting?  It sounds as though you feel it's a setting or app/feature or program on your PC that's causing this?
Lee_R
mickywaz
  • 8
Message 7 of 8
Hey. Yeah I've sorted it. Turns out the port on my motherboard was giving up. Got a new ethernet PCI card and it's fixed the issue. Board is Asus Rog Z390-F Capable of doing the 1gig but ended up buying a card that can do 2.5gb. so future proofed myself a little.
Gareth_L
  • 10.8K
  • 601
  • 1.2K
Message 8 of 8
That's more than future proofed mickywaz
Thanks for letting us know
Gareth_L
