billc47
  • 30
Message 1 of 28
Slower speed after upgrade
A Virgin engineer visited this morning to upgrade my M350 broadband with no telephony service to M500 Broadband with telephony.  The visit smply involved attaching a small phone adapter to the router.  He advised that the speed upgrade would take anywhere between 5 minutes and 2 hours to become active.
My speed after 4 hours has reduced to little more than 200 where I was getting 320-350.  No sign of a speed increase.  Is it possible that the service reconfiguration has not been implemented properly?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 28
Re: Slower speed after upgrade
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow warning click the Post button again.
billc47
  • 30
Message 3 of 28
Many thanks for the quick reply.  I think I’ve followed the instructions for the BQM properly
My BQM
billc47
  • 30
Message 4 of 28
13230000002.738256 qam24
21870000003.738256 qam7
31950000003.738256 qam8
42030000003.538256 qam9
52110000003.438256 qam10
62190000003.538256 qam11
72270000003.438256 qam12
82350000003.238256 qam13
9243000000338256 qam14
102510000002.938256 qam15
112590000002.938256 qam16
122670000002.738256 qam17
132750000002.738256 qam18
142830000002.738256 qam19
152910000002.738256 qam20
162990000002.938256 qam21
173070000002.738256 qam22
183150000002.738256 qam23
194430000003.238256 qam25
20451000000338256 qam26
21459000000338256 qam27
22467000000338256 qam28
23475000000338256 qam29
244830000003.438256 qam30
1Locked38.9159266
2Locked38.63570
3Locked38.93890
4Locked38.63850
5Locked38.93230
6Locked38.932615
7Locked38.648314
8Locked38.667714
9Locked38.65310
10Locked38.63610
11Locked38.93370
12Locked38.95240
13Locked38.61491106
14Locked38.91965386
15Locked38.9135780
16Locked38.63750
17Locked38.62951
18Locked38.64020
19Locked38.62540
20Locked38.62290
21Locked38.62474
22Locked38.63040
23Locked38.93310
24Locked38.92840
billc47
  • 30
Message 5 of 28
1325999863.65512064 qam10
2394000003.675512064 qam9
3462000003.65512064 qam8
4258000003.675512064 qam12
3ATDMA0000
4ATDMA0000
billc47
  • 30
Message 6 of 28
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxxl500u+voc-b.cm
SFID206436
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID206435
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
billc47
  • 30
Message 7 of 28
01/01/1970 00:01:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2020 08:04:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2020 12:39:40ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2020 01:01:10ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 19:07:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 13:22:44ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/08/2020 06:30:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 00:00:54ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 20:37:16ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/08/2020 10:01:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/08/2020 16:10:50ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/08/2020 13:20:34ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/08/2020 12:45:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/08/2020 17:29:9ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2020 11:48:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/08/2020 13:40:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/08/2020 13:40:9criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/08/2020 10:13:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/08/2020 06:16:34ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
jhuk
  • 3K
  • 52
  • 286
Problem sorter
Message 8 of 28
No clue why an engineer visit was needed to press a button on a computer and give your account  a new Faster Config file esp 350>500 as it is the same HUB3.
I assume he connected his meter to test the power levels to see if they were within OK levels.
Many like myself on this very forum found we went from a 99.9% of the time stable 350 full speed to not so stable 500 (I had 500 for about 1-2months AFAIR) and same again for me the past week now on 1Gb/s but with a HUB4.
billc47
  • 30
Message 9 of 28
Not that I noticed, I’m sure his actions were limited to connecting the telephone dongle into the back of the router.
jhuk
  • 3K
  • 52
  • 286
Problem sorter
Message 10 of 28
I am not in the correct colour zone (Red/Purple etc) for that yet so no VOIP phone for me so it is the old method not connected to the HUB.
