jlb9900
Message 1 of 19
Slower ethernet than wireless
So I have just finished doing up my house & I have ran a cat 6 ethernet cable from a wall box to another wall box in another room. I used the proper tools & even checked the cable for corruption. I get 1gb internet from virgin and over wireless I get about 500mb. through the port I put in I only get 100mb/s. Do virgin routers cap some ethernet connections? or is it just my setup is faulty. logged into the router page and it gave me this (below). Any advice would be greatly appreciated. cheers
iPad-2 192.168.0216Wi-Fi 5G VM6302302
unknown 192.168.00Wi-Fi 5G VM6302302
PC 192.168.0100Ethernet
PC-1 192.168.0104Wi-Fi 2.4G VM6302302
carl_pearce
  • 1.77K
  • 114
  • 378
Super solver
Message 2 of 19
Re: Slower ethernet than wireless
Either your:
  • device isn't capable of 1Gbps (has a 10/100 ethernet port).
  • cable is cat 5, which is only capable of 10/100.
  • cable is faulty.
  • HUB is faulty.
  • wiring on the ethernet cables is bad.
Plug a wired device directly into the HUB with a standard ethernet cable and check if the device connects at 1000.
jlb9900
Message 3 of 19
I've had the pc connected to a network at 350mb before and it worked fine.
the cable is definitely a cat 6 as I installed it myself & just checked my amazon orders to make sure haha.
I used a cable tester on the line after I put it in and it gave me 8 greens.
Do you think its something I should take up with Virgin?
carl_pearce
  • 1.77K
  • 114
  • 378
Super solver
Message 4 of 19
I updated my post above to suggest plugging in a device directly to the HUB with a shorter known good ethernet cable.
jlb9900
Message 5 of 19
Unforuntely I don't have a different device I can plug in right now. the speed is capped over wireless also on my PC at 104mb.
carl_pearce
  • 1.77K
  • 114
  • 378
Super solver
Message 6 of 19
I don't think there is any need to contact VM until you've proven your wiring is capable of 1Gbps.
Do you have a spare switch you could plug into the ethernet wall socket instead of the HUB to check the LEDs show 1Gbps?
jlb9900
Message 7 of 19
All sorted, it was the connecting wires between the wall plates & the router/pc. sorry for wasting your time haha.
carl_pearce
  • 1.77K
  • 114
  • 378
Super solver
Message 8 of 19
No worries, it's always worth talking stuff through...
Tom_W1
  • 3.66K
  • 198
  • 342
Message 9 of 19
Hi @jlb9900, thanks for your post although I'm sorry you were having some problems originally.
Great to hear that this is all sorted though, thanks for to the help of @carl_pearce that's much appreciated.
Please don't be shy to create a new forum post if you ever need any help on other topics in the future 🙂
Many thanks
Tom_W
Mtechx
  • 8
Message 10 of 19
Hello
Am also having the same issue.
Have a cat 5 cable but only getting 80mb but wireless getting 200 plus on laptop
Is this a cable issue.  Sorry not cable savvy.
Any info would be appreciated.
New installation with the HUB 3
