joewebber
  • 18
Message 1 of 19
Slower broadband speed after upgrade
I recently upgraded from 200mb to 350mb package. I have the Super Hub 3, and have tested using a wired connection, with a single device wired into the hub. Previously was getting 200+ down and 20+ up. Now getting 40mb/40mb.
I have tried the following:
  • Factory reset the hub (twice. Using the method of holding the reset button for 60 seconds)
  • Connected using Cat 6 and Cat 7 cables
  • Tested Wifi connection with a single device placed next to the router
I have seen other people with this issue who have required a settings update at Virgin's end, or a replacement router.
Any help would be appreciated. I have been with Virgin a long time, but thinking strongly of leaving. I have issue with the Super Hub 3 not working in modem mode, due to a fault with the Puma chipset. If this isn't fixed by the Super Hub 4, I will be off to BT
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 19
Re: Slower broadband speed after upgrade
Please do this before posting the Hub Data
joewebber
  • 18
Message 3 of 19
Thanks. I have a BQM set up from a previous issue:
My BQM
Also, I can't see an option to check router status on the login screen?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 19
Your >> BQM << is showing typical signs of over utilisation which is only to be expected with so many people schooling and working from home.
A good friend of the forums @Andruser has commented on the forum about similar problems to yours ...
https://community.virginmedia.com/t5/Speed/Advice-on-stats-etc/td-p/4555347/page/2
https://community.virginmedia.com/t5/Networking-and-WiFi/Poor-BQM/m-p/4557860#M365466
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 19
Can you please post your Hub data. just to see if there is anything else lurking in the background.
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Please do not use screen shots.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
joewebber
  • 18
Message 6 of 19
I understand the over-utilisation is an issue at the moment, what doesn't make sense is the speed drop straight after the upgrade.
Even with the over-utilised network I was getting around 200mb prior to the upgrade
joewebber
  • 18
Message 7 of 19
Status
659000000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
joewebber
  • 18
Message 8 of 19
Downstream
1659000000-1.737256 qam32
2411000000-1.537256 qam1
3419000000-1.537256 qam2
4427000000-1.237256 qam3
5435000000-1.237256 qam4
6443000000-1.237256 qam5
7451000000-1.237256 qam6
8459000000-137256 qam7
9467000000-1.237256 qam8
10475000000-1.238256 qam9
11483000000-138256 qam10
12499000000-137256 qam12
13507000000-0.938256 qam13
14515000000-0.737256 qam14
15547000000-137256 qam18
16555000000-1.238256 qam19
17563000000-1.537256 qam20
18571000000-1.737256 qam21
19587000000-237256 qam23
20595000000-237256 qam24
21603000000-1.737256 qam25
22611000000-1.737256 qam26
23619000000-237256 qam27
24651000000-1.937256 qam31
1Locked37.370
2Locked37.3130
3Locked37.310
4Locked37.650
5Locked37.350
6Locked37.640
7Locked37.360
8Locked37.350
9Locked37.640
10Locked38.640
11Locked38.650
12Locked37.650
13Locked38.960
14Locked37.660
15Locked37.620
16Locked38.650
17Locked37.650
18Locked37.650
19Locked37.660
20Locked37.600
21Locked37.660
22Locked37.960
23Locked37.640
24Locked37.340
joewebber
  • 18
Message 9 of 19
Upstream
14620000044.8512064 qam1
22580000043.8512064 qam4
33260000044.5512064 qam3
43940000044.3512064 qam2
1ATDMA0010
3ATDMA0000
4ATDMA0000
joewebber
  • 18
Message 10 of 19
Configuration
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID62840
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID62839
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
