Slow
Jedi1
Very slow upload and download speeds  even with a wired ethernet connection. Should be getting 250mbs  however I don't even get half that.
1 REPLY 1
Trouble shooter
Speed test the service to a Router mode Hub(3/4/5) + your device with the link below.
The speed at the Hub should reflect your subscription.
The speed any WiFi device draws data at is limited by its data needs and technical abilities.
