SteveTheDude
  • 8
Slow wired connection
Hi All,
Currently subscribed to M200 broadband package with my superhub 3 about 30cm away from my laptop using a wired connection.
I keep experiencing very slow speed when I perform a speed test, sometimes upto 90mbps and sometimes as low as 10-15mbps.
I'd like to know :
A) anything I can do to improve this.
B) do I require a new superhub.
C) is it worth going down the route of buying a router and using the superhub as a modem only.
Please be aware that I'm a bit of a noob so any and all advice would be greatly appreciated.
Steve
gary_dexter
  • 30.5K
  • 1.89K
  • 4.05K
Re: Slow wired connection
What is the spec of the cable (printed on the cable sheath) and the make/model of the NIC on the laptop?
SteveTheDude
  • 8
Apologies for delay.
The cable is Cat.5e.
And the NIC is listed as Realtek. RTL. 8188EE. Incidentally, I've just updated the drivers for this too.
