kevsn1
  • 16
Slow wifi
Hi all,
Ive never had issues with wifi until recently. Im currently on m500 but im averaging 250mbps with only my device connected. Ive tried resets with no change. Strange when i was on m350 i always got 350 and beyond
Any ideas
  • 20.7K
  • 2.2K
  • 3.66K
Re: Slow wifi
If you think that you have a BB speed problem, then to check the speeds coming in to your Hub properly, and whether they match what you should be getting, you cannot rely on wifi tests, - no BB supplier guarantees those - only speeds "TO" the Hub are guaranteed.
So, can you test speeds directly like this. As you expect >100Mbps then connect a 1GB enabled computer/laptop, with up to date drivers, via a known good and working Cat5e (or better) ethernet cable, directly to the Hub which you have put into “modem mode” (see VM website for “How To”). Test at speedtest.net (not using their App!) to your nearest VM server - try on 2 different browsers.
If they are still low – boot the device into windows safe+networking mode and try again.
There are many posts on here where unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
  • 15.46K
  • 662
  • 1.51K
Re: Slow wifi
As a experiment go back to 350M and see what speed you get.
apcyberax
  • 33.51K
  • 1.88K
  • 5.96K
Re: Slow wifi
250 is good for wifi.
