Higginss
Slow wifi
Evening new to virgin was expecting good things, we should be getting 100 + speeds. Last four days only getting 2 / 3 on a speed test (wifi) and hard wired tv struggling as well
I reset the box and for the first 5mins getting 110 / 112
Then drops right down, customer services have said to monitor it and get back to them.
I've checked the connections and all good
Is this the best customer service I should expect as I will probably cancel my contract
Thanks in advance
xl3ombz
  • 34
Re: Slow wifi
i have the exact same problem im on the 500MB package and im getting 1MB. I reset the box and for the first couple of minutes i get 100-150 MB then straight back down to 1MB.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow wifi
@Higginss wrote:
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow wifi
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
