iceman291uk
Slow wifi
I have 350 virgin package and my WiFi is only 20 so super slow??? What can I do?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow wifi
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
iceman291uk
Re: Slow wifi
about 28 so nowhere near 350 😞
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow wifi
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
