obistudio
Slow wifi speed
Hello there,
We had virgin engineer installed our M500 package about 2 month ago. I have my pc connected to the router directly via lan cable and the speed is around 500mb all day except at night! I have noticed about 10pm the speed slows down to 80-100mb which is 1/5 of the speed I am supposed to get. So this is one problem I need help with to sort it out. My other issue is that since the day our broadband was installed I am only getting 190mb via wifi on my iPhone and my iPads. No download or anything is going on any of my devices or computers but when I do speed test, every single time is the same 190mb download speed I get and I am sitting right next to the router. I already tried to restart router but nothing has changed.
Can anyone help me to sort out these two issues please?
Thank you in advance.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow wifi speed
The Wi-Fi speeds you are getting are pretty decent for a VM Hub and to be honest it should not be a problem.
As for the ethernet connected PC slowing down, we might as well start with the basics ...
Then
Can you please
