aj26
  • 35
Slow upload speeds and packet loss
Getting slow upload, packet loss and intermittent latency issues.
3.0 Upstream channels
16030000038.5205995120 KSym/sec64QAM9
22580000048.2705995120 KSym/sec8QAM14
33260000045.2705995120 KSym/sec64QAM13
43940000046.2705995120 KSym/sec64QAM12
1US_TYPE_STDMA00140
2US_TYPE_STDMA00140
3US_TYPE_STDMA00140
4US_TYPE_STDMA00140
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow upload speeds and packet loss
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
aj26
  • 35
monitoring screenshot already added just waiting for admin to approve
aj26
  • 35
upstream info added - shows issue with modulation, no issues with download.
aj26
  • 35
https://www.thinkbroadband.com/broadband/monitoring/quality/share/dcd231c36b398ca33522176ebdac41519206aa9a-06-01-2021
