Can you please do the following:
For Hub 2 & 3 When the page appears DO NOT LOG IN but click ‘Check Router Status’.
For Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow warning just click the Post button again. Use one post for each item if needed.
