KN2
  • 14
Message 1 of 5
Slow upload speed
Like others here, I've been suffering with slow upload speeds during peak times over the past month. Currently on 100Mbps down (getting 110Mbps usually) and 10Mbps up (going as low as under 1Mbps during peak times, before 9am ok). It makes working from home with conference calling and screen sharing problematic. Customer services has been less than helpful unfortunately. I'm hoping somebody here will be able to help.
I have ran tests with no other devices connected, modem mode on and off, rebooted and factory reset the Superhub 3.
Logs as follows with upload speed currently at 1.86Mbps (tested via ethernet cable):
04/06/2020 18:14:10noticeLAN login Success;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
03/06/2020 23:48:27criticalNo Ranging Response received - T3 time-out;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
03/06/2020 22:47:28ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
03/06/2020 22:17:53ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
03/06/2020 21:56:18criticalNo Ranging Response received - T3 time-out;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
03/06/2020 14:54:55ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
03/06/2020 12:57:26criticalNo Ranging Response received - T3 time-out;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
03/06/2020 07:02:24ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 18:30:0Warning!RCS Partial Service;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 16:02:57criticalNo Ranging Response received - T3 time-out;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 15:17:25ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 15:07:15criticalNo Ranging Response received - T3 time-out;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 19:47:26ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 19:29:7ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 18:22:8ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 18:10:51ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 17:29:38ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 15:01:4ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
1462000004.425512032 qam1
2257993374.375512032 qam4
3394000004.4512064 qam2
4326000004.375512064 qam3
3ATDMA0000
4ATDMA0000
Thank you.
DJ_Shadow1966
  • 6.87K
  • 1.31K
  • 1.9K
Message 2 of 5
Re: Slow upload speed
Hello
Can you also post your downstream stats, there is nothing that shows any issues in your upstream, although the logs do show quite a high number of T3 timeouts.
Regards Mike
DeeRock
  • 16
Message 3 of 5
I'm the same, before 9am I'm 7 mbps instead of 32 mbps. I require more than 7 mbps as I upload steady at 5 - 6 mbps consistently. Same times as me, seems like more and more people are coming forward, they have to be throttling this. Once again every member of staff is telling me 'There seems to be no problem' but there evidently is. I'll keep watching this post incase you find a solution for this before mine is resolved!
KN2
  • 14
Message 4 of 5
Here's the downstream as of 12.42 BST 5/6/2020 - currently on a pitiful 0.7Mbps upload speed
14110000004.436256 qam1
2419000000436256 qam2
3427000000436256 qam3
44350000003.736256 qam4
54430000003.736256 qam5
6451000000436256 qam6
74590000004.437256 qam7
84670000004.537256 qam8
94750000004.937256 qam9
10483000000537256 qam10
114910000005.437256 qam11
124990000005.537256 qam12
135070000005.637256 qam13
145150000005.937256 qam14
15523000000637256 qam15
165310000006.337256 qam16
175390000006.138256 qam17
185470000006.137256 qam18
195550000006.437256 qam19
205630000006.538256 qam20
215710000006.538256 qam21
225790000006.638256 qam22
235870000006.538256 qam23
245950000006.538256 qam24
1Locked36.35940
2Locked36.67030
3Locked36.35620
4Locked36.66260
5Locked36.37070
6Locked36.67290
7Locked37.66840
8Locked37.37160
9Locked37.66640
10Locked37.37990
11Locked37.68020
12Locked37.66730
13Locked37.37240
14Locked37.39880
15Locked37.69520
16Locked37.69930
17Locked38.69180
18Locked37.611070
19Locked37.610690
20Locked38.612020
21Locked38.612210
22Locked38.611400
23Locked38.610600
24Locked38.68010
Steven_L
  • 4.65K
  • 340
  • 462
Message 5 of 5
Sorry to hear of the issues that you've been having with your services KN2.
I have been able to locate your account and found that there is high utilisation ticket raised in your area. you might find that your Virgin Fibre, Virgin TV or TiVo® services are intermittent, with the picture freezing or disappearing now and then.
We are planning to undertake some upgrades to support the increased demand for our services in your area. When completed, any slow broadband speeds and buffering on TiVo apps you may be experiencing (particularly at peak times) will be resolved.
The current estimated fix date and time are 24th June at 17:30.
Steven_L
