stroebs
Slow upload speed + packet loss
Suddenly experiencing incredibly slow upload speed making the connection somewhat unusable.
Connection: M100
Hub: 3.0
BQM: https://www.thinkbroadband.com/broadband/monitoring/quality/share/32c75ba38ad3969f1e115622fe9a781a25...
Experiencing a steady 10-11% packet loss.
Have:
- Rebooted hub
- Reset hub to default
- Set to modem mode (and back to router mode)
- Swapped between ethernet and WiFi
Speedtest result: https://www.speedtest.net/result/10501789779
Download: 49.59Mbps
Upload: 0.32Mbps
139000000
Locked
Ranged Upstream Channel (Hz)
39399013
Locked
Provisioning State
Online
LOG:
01/01/1970 01:10:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:08:31ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:06:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:56:12ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:54:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:54:27ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:54:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:51:8ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:48:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:46:53ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:45:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:37:13ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:35:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:30:33ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:30:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:27:40ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:24:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:20:28ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:20:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:13:21ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
stroebs
Re: Slow upload speed + packet loss
11390000007.440256 qam1
21470000007.440256 qam2
31550000007.140256 qam3
4163000000740256 qam4
51710000006.940256 qam5
61790000006.540256 qam6
71870000006.340256 qam7
8195000000640256 qam8
92030000005.940256 qam9
102110000005.640256 qam10
112190000005.540256 qam11
122270000005.540256 qam12
132350000005.540256 qam13
142430000005.140256 qam14
15251000000540256 qam15
16259000000540256 qam16
172670000004.940256 qam17
182750000004.640256 qam18
192830000004.840256 qam19
202910000004.540256 qam20
212990000004.840256 qam21
223070000004.640256 qam22
233150000004.840256 qam23
243230000004.640256 qam24
1Locked40.350
2Locked40.370
3Locked40.360
4Locked40.370
5Locked40.340
6Locked40.950
7Locked40.960
8Locked40.960
9Locked40.380
10Locked40.360
11Locked40.9100
12Locked40.390
13Locked40.9100
14Locked40.990
15Locked40.9110
16Locked40.380
17Locked40.360
18Locked40.970
19Locked40.950
20Locked40.380
21Locked40.990
22Locked40.380
23Locked40.340
24Locked40.920
13939901340.5512016 qam8
25370100941.3512016 qam6
36030106641.3512016 qam5
44619949941512016 qam7
1ATDMA0050
2ATDMA0040
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057+voc-b.cm
SFID338384
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID338383
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
