Anonymous
Not applicable
Slow upload speed on Gig1
I posted this earlier on the wrong account so here goes again...
I am seeing reduced upload speeds of around 15-25Mb all the time. 25Mb is rare, it is normally closer to 15Mb.
I have spoken to second line support, after waiting 1.5 hours and being transferred to 3 different people, to be told basically Virgin don't care about what upload speed you are getting it's not guaranteed and that there is no problem on my line.
Thing is, I have been told all upstream channels should be 64QAM, I have 1-2 channels at a time that are dropping down to 32QAM. Although second line support told me this is expected behaviour.... It was not like this when first installed so I find it hard to believe this is expected.
I have reset, tried different cables, devices, ensured the coax cables are connected correctly, tried with and without the attenuator fitted by an engineer for my old Hub 3. Still the same issues.
Live BQM
My BQM looks awful, it has actually generally been ok (see below for snapshot from 11.01.21)
11.01.21 BQM
SamKnows real speed test shows around 21Mb upload hitting the router right now. Download is fine, I am testing on a wired gigabit enabled connection.
Please, could someone confirm if there is a problem here or not, phone support don't seem to be all that helpful.
I will post router info below.
Anonymous
Not applicable
Re: Slow upload speed on Gig1
3.0 Downstream channels
304027500001.29999938.983261QAM25630
11387500000.70000137.636276QAM2561
21467500000.29999937.636276QAM2562
31547500000.29999938.605377QAM2563
41627500000.29999938.983261QAM2564
51707500000.09999837.636276QAM2565
61787500000.09999838.983261QAM2566
71867500000.00000038.605377QAM2567
81947500000.09999838.605377QAM2568
92027500000.29999938.983261QAM2569
102107500000.09999838.605377QAM25610
112187500000.20000137.935909QAM25611
122267500000.20000138.605377QAM25612
13234750000-0.50000038.983261QAM25613
14242750000-0.09999838.983261QAM25614
15250750000-0.29999938.605377QAM25615
16258750000-1.09999838.605377QAM25616
17266750000-1.00000038.605377QAM25617
18274750000-1.09999838.605377QAM25618
19282750000-0.29999938.605377QAM25619
202907500000.40000238.983261QAM25620
212987500000.50000038.983261QAM25621
223067500000.79999938.983261QAM25622
233147500001.20000138.605377QAM25623
243227500001.79999938.983261QAM25624
253307500001.90000238.983261QAM25625
263707500001.20000138.983261QAM25626
273787500001.20000138.605377QAM25627
283867500001.50000038.605377QAM25628
293947500001.40000238.605377QAM25629
314107500001.59999838.983261QAM25631
30Locked000
1Locked16371250600
2Locked20909907100
3Locked16205513500
4Locked15995432500
5Locked15766400400
6Locked15940837600
7Locked20648337300
8Locked14071721800
9Locked14058500100
10Locked14009433800
11Locked13906855200
12Locked18548844500
13Locked14103013700
14Locked13861760400
15Locked13730968000
16Locked14545013900
17Locked14704564700
18Locked14363161400
19Locked14586009300
20Locked13291741900
21Locked14286619000
22Locked14275806500
23Locked14445551000
24Locked18376548000
25Locked18615631400
26Locked18275379500
27Locked18448742800
28Locked18288014200
29Locked18017521500
31Locked22190845200
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
33864K1680QAM4096424
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
33Locked 0.535646160
Anonymous
Not applicable
3.0 Upstream channels
13260000042.5205995120 KSym/sec64QAM5
25370000043.2705995120 KSym/sec64QAM2
33940000042.7705995120 KSym/sec64QAM4
44620000042.7705995120 KSym/sec32QAM3
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
