brapalap
Slow upload speed, North London
I noticed a few days ago my e-mails were taking forever to send, especially with attachments. Not to mention we use a Remote Desktop Server for most of our work and that rely's heavily on connection speed... Which has meant work has been painfully slow for me.
After many speed tests, I can see my upload rate has been significantly slow. Between 0 and 1 Mbps. Download speed is fine, no issues there, I get 55 to 60 Mbps.
I am on a wired connection and I have also tried wireless, both give the same result. I am based in Haringey, North London and the VM area service status says there is no problem.
Can someone at VM help me with this?
13870000001140256 qam32
220300000010.540256 qam9
321100000010.540256 qam10
421900000010.540256 qam11
522700000010.540256 qam12
623500000010.540256 qam13
724300000010.340256 qam14
825100000010.440256 qam15
925900000010.440256 qam16
1026700000010.140256 qam17
112750000001040256 qam18
1228300000010.440256 qam19
1329100000010.840256 qam20
142990000001140256 qam21
153070000001140256 qam22
1631500000011.140256 qam23
173230000001140256 qam24
1833100000010.840256 qam25
193390000001140256 qam26
203470000001140256 qam27
2135500000010.840256 qam28
223630000001140256 qam29
2337100000011.340256 qam30
2437900000011.340256 qam31
1Locked40.900
2Locked40.330
3Locked40.360
4Locked40.960
5Locked40.940
6Locked40.350
7Locked40.900
8Locked40.950
9Locked40.940
10Locked40.960
11Locked40.940
12Locked40.940
13Locked40.360
14Locked40.350
15Locked40.950
16Locked40.960
17Locked40.350
18Locked40.940
19Locked40.360
20Locked40.350
21Locked40.360
22Locked40.360
23Locked40.940
24Locked40.950
16030023838.5512064 qam1
23940001538.5512016 qam4
34619982938.3512016 qam3
45370036238.3512016 qam2
2ATDMA0010
3ATDMA0000
4ATDMA0000
Network LogTime Priority Description
09/04/2021 13:02:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/04/2021 12:25:27noticeReceived REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2021 05:33:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2021 00:21:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2021 03:49:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/04/2021 12:21:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2021 03:22:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2021 00:21:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2021 13:25:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/03/2021 12:41:22ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/03/2021 21:50:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/03/2021 02:21:49criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/03/2021 02:20:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/03/2021 02:13:51criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/03/2021 02:11:50Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/03/2021 02:11:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/03/2021 02:11:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/03/2021 02:11:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/03/2021 23:01:6ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I suspect the slow upload rate is affecting other areas of the house that rely on internet. I have since unplugged all of these to see if it was affecting it... No changes... Ah the joys of a "smart home"...
  • 22.49K
  • 2.41K
  • 4.02K
Re: Slow upload speed, North London
Your connection is not good. All of the down channels are at too high power - recommended max is +10dBmV. And 3 up channels have dropped to 16qam. You need someone from VM to look at it - but it will need a Tech visit to balance the signal.
Call it in on 150 (VM Phone - free) or 0345 454 1111 (any other phone - national rate). Calling at 08.00 midweek (09.00 Sun) is the best time to get through quickly. Although some people are still reporting getting through fine at other times with no long waits so worth trying now
If you get cut off after an automated reboot cycle, just call back in a couple of minutes as the system should know that you have just been on and it hasn’t helped and put you in the queue.
Or try options 1,1,4,4, “thinking of leaving” - they usually pick those calls up quickly and then transfer you to the appropriate queue (or cut you off !).
A VM person should pick this up here and respond, but it can take a few days for them to get here.
Serena_C
  • 330
  • 15
  • 37
Hi @brapalap,
Thank you for your post regarding your slow upload speeds, sorry to see that you are having issues with your connection. I am going to send you a PM so that we can take a look into this further for you now.
Serena
