Lcooper119
  • 5
Message 1 of 8
Slow upload speed M100
I usually get an upload speed of around 7-10Mbps as expected with M100, but recently it's been more like 1-5Mbps which just isn't good enough for me, download speeds are absolutely fine at 100Mbps+.
I'm using a wired connection from my PC to my Hub 3, and nothing has changed with my setup, is there some kind of capacity issue in my area perhaps?
  • 22.5K
  • 2.41K
  • 4.02K
Message 2 of 8
Re: Slow upload speed M100
You could try a factory reset – a lot of the VM techies on here are suggesting it as a first option and it has helped many customers.
Note that a pinhole reset on a Hub3 can be a bit problematic - so do it EXACTLY this way (not as the VM website says!).
Firstly, make sure the Hub's sticker/card with the two passwords on it is still there and legible or you will be stuffed ! If its not – DON’T DO IT !
With the Hub switched "on", disconnect any ethernet connections and then push in the “reset pin” with the end of a paperclip/thin nail or similar (bigger items like ball point pen ends may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT restart the Hub after that. Leave it 10' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings/admin one to access the Hub (it is a six digit numeric one).
Lcooper119
  • 5
Message 3 of 8
I tried as you suggested, no difference unfortunately. Been trying to find out about faults/congestion or if there's a scheduled fix in my area but VM have just been sending me in circles between their teams.
Andrew-G
  • 6.18K
  • 1.09K
  • 2.62K
Message 4 of 8
As a general rule capacity issues affect the downstream far more often than upstream.
You may want to connect to the hub, click "check router status" and then post the data from Downstream, Upstream and Network log.  Post as formatted text, not images, and we can see if there's obvious power or noise problems.
Lcooper119
  • 5
Message 5 of 8
13307500001040256 qam25
22667500009.640256 qam17
32747500009.540256 qam18
42827500009.540256 qam19
52907500009.540256 qam20
62987500009.838256 qam21
73067500009.640256 qam22
83147500009.840256 qam23
93227500001040256 qam24
103707500009.340256 qam26
11378750000938256 qam27
123867500008.640256 qam28
133947500008.440256 qam29
144027500008.140256 qam30
15410750000838256 qam31
164187500007.840256 qam32
174267500007.540256 qam33
184347500007.338256 qam34
194427500006.938256 qam35
204507500006.638256 qam36
214587500006.538256 qam37
224667500006.538256 qam38
234747500006.638256 qam39
244827500006.638256 qam40
1Locked40.380
2Locked40.9100
3Locked40.370
4Locked40.350
5Locked40.990
6Locked38.9210
7Locked40.3100
8Locked40.3110
9Locked40.3110
10Locked40.340
11Locked38.990
12Locked40.9110
13Locked40.3120
14Locked40.3110
15Locked38.960
16Locked40.380
17Locked40.3130
18Locked38.9100
19Locked38.9120
20Locked38.6160
21Locked38.9240
22Locked38.9170
23Locked38.9110
24Locked38.960
Lcooper119
  • 5
Message 6 of 8
1461999664.2512064 qam2
2537000054.4512064 qam1
3325999073.95512064 qam4
4394000004.1512064 qam3
3ATDMA0000
4ATDMA0000
Lcooper119
  • 5
Message 7 of 8
12/06/2020 12:09:8noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2020 12:08:48Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2020 11:31:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2020 13:57:30ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2020 08:22:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2020 04:06:53ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2020 15:06:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 03:55:40ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2020 20:25:36ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/06/2020 00:49:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 01:21:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 01:21:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 01:21:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 01:21:43criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 01:21:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 01:21:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 01:21:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 01:21:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Steven_L
  • 4.65K
  • 340
  • 462
Message 8 of 8
Sorry to hear that you're having issues with your connection Lcooper119. I have looked into your account and have not been able to find any reason why this would be happening to you.
We have no faults listed on our system for your area that could also be causing the issues you're having.
Our system has stated a new hub could resolve the issue, I can arrange that over a private message, which I will drop over in a moment.
Steven_L
