bengeo
  • 19
Message 1 of 12
Slow upload and packet loss
I have a Hub 3 in modem mode to a Linksys Mesh Router. All was working well until very recently.
Now getting very slow upload speeds:
Also Thinkbroadband checker shows 100% dropped packets:
I have restarted everything several times.
Thanks for any help,
Andy
Tags (1)
  • 6.1K
  • 513
  • 1.57K
Message 2 of 12
Re: Slow upload and packet loss
Your Upstream should all be 64QAM so that needs fixed. As for the BQM you need to allow Respond to ping on the Router.
bengeo
  • 19
Message 3 of 12
Thanks for the info.
John_GS
  • 14.45K
  • 738
  • 1.35K
Message 4 of 12
Hi bengeo,
Thanks for posting. Sorry to hear of the broadband issues. You were affected by a noise on the line issue. Fault reference is F009543083. The ticket is showing restored but is under monitoring from the field and networks team.
How's the speeds been since posting?
Best.
John_GS
bengeo
  • 19
Message 5 of 12
Hi John,
The speeds seem to be back to normal now, but there are still some oddities.
The Hub 3 is in modem mode and I can only access it via 192.168.100.1 just after it has been restarted. At any other time it says "The connection has timed out". Also, when I first open a browser the first site has a delay before it loads and then it seems normal after that. I still have 1 upload channel at 32 qam.
Info:
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300000
49
5120
64 qam
1
2
39400000
46.8
5120
64 qam
4
3
46200000
47.3
5120
32 qam
3
4
53700000
48.5
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID
23696
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
23695
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
Andy
Ashleigh_C
  • 4.24K
  • 170
  • 318
Message 6 of 12
Hi @bengeo
Thank you so much for updating us and I'm so sorry to hear that these drops and messages have been happening!
I know it's been a few days since your last post and the network teams were still monitoring the closed outage so I just wanted to check how things were looking now?
Thank you.
Ash_C
bengeo
  • 19
Message 7 of 12
Hi Ash,
The speeds seem to be normal, but there are still some oddities.
The Hub 3 is in modem mode and I still can only access it via 192.168.100.1 just after it has been restarted. At any other time it says "The connection has timed out". Do I need a new hub?
In my last message I said that I had 1 upload channel at 32 qam. Now it is worse:
Andy
Lee_R
  • 6.3K
  • 291
  • 656
Message 8 of 12
Hi @bengeo thanks for getting back to us.
When you say "restarted" do you mean rebooting of your hub or a full pinhole reset?  As the pinhole reset essentially takes the hub back to factory settings, but clears most issues.
Lee_R
bengeo
  • 19
Message 9 of 12
Hi Lee,
I haven't done a full pinhole reset yet. I am waiting until I have enough time to set everything up again as I will want it back in modem mode.
The status checker is still saying that there are problems.
I'll do that reset soon and report back.
Andy
Zak_M
  • 6.12K
  • 315
  • 545
Message 10 of 12
Good morning Bengeo,
Thank you for coming back to us,  I have just taken a further look over your account and I can see that there is an SNR issue in your area, the ETA for fix is today, however with SNR issue they are notoriously difficult to locate the problem area so I would expect this to be delayed somewhat.
Kind regards,
Zak_M
