dariusm
  • 6
Settling in
Message 1 of 10
Slow, unstable connection
I'm on a 100MB package and have to remote into my PC at work on a daily basis. My connection has never been great, however it has become markedly worse over the past few weeks, either providing me with a unworkable lag or kicking me out entirely. This is an issue with my broadband connection rather than on my work servers, as using my phone as a hotspot yields no issues.
Live BQM Graph
Speedtest 1
Speedtest 2 (few mins later)
I'm connected to the router via an ethernet cable, so it's not a WiFi issue. Have tried restarting the router, re-seating all cables both inside and outside the house with no luck.
While I appreciate there is heavy load on the network at the moment, and i'm not expecting sub-30 ping on a consistent basis, I do expect at least expect a stable, workable connection. Service status shows no issues in my area, as it always has. Any suggestions would be much appreciated. I'm at the end of my tether. I'm in the E18 postcode area if that is any use.
14/01/2021 05:15:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 02:09:49noticeSW download Successful - Via NMS
14/01/2021 02:08:6noticeSW Download INIT - Via NMS
13/01/2021 10:05:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 09:20:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 21:24:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 20:19:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:02:21Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 14:43:9noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 13:36:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 17:14:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 15:36:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 15:36:18Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 20:49:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 18:28:18ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 01:05:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 00:19:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 17:24:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 17:10:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Pinging google.co.uk using the tool in the router
PING google.co.uk (216.58.205.35): 64 data bytes
72 bytes from 216.58.205.35: seq=0 ttl=116 time=150.000 ms
72 bytes from 216.58.205.35: seq=1 ttl=116 time=150.000 ms
72 bytes from 216.58.205.35: seq=2 ttl=116 time=12940.000 ms
72 bytes from 216.58.205.35: seq=3 ttl=116 time=14930.000 ms
--- google.co.uk ping statistics ---
10 packets transmitted, 4 packets received, 60% packet loss
round-trip min/avg/max = 150.000/7042.500/14930.000 ms
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 10
Re: Slow, unstable connection
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 10
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
dariusm
  • 6
Settling in
Message 4 of 10
Thanks for the response.
Reported speed for the ethernet device is 1000Mbps
Samknows result:
Latency: 68.5 ms
Jitter: 45.6 ms
Download: 31.2 Mbps
Upload: 878 Kbps
The only other device connected currently is the Macbook I am using to post this, which is connected via WiFi.
dariusm
  • 6
Settling in
Message 5 of 10
Downstream
13307500004.837256 qam25
22027500001.436256 qam9
32107500001.236256 qam10
42187500000.936256 qam11
52267500000.536256 qam12
6234750000-0.236256 qam13
7242750000-0.536256 qam14
8250750000-0.236256 qam15
92587500000.736256 qam16
102667500001.536256 qam17
11274750000236256 qam18
122827500002.736256 qam19
132907500003.536256 qam20
142987500003.936256 qam21
153067500003.936256 qam22
163147500004.137256 qam23
173227500004.337256 qam24
183707500002.237256 qam26
193787500001.536256 qam27
203867500000.736256 qam28
213947500000.236256 qam29
22402750000036256 qam30
23410750000036256 qam31
244187500000.236256 qam32
1Locked37.3130
2Locked36.390
3Locked36.360
4Locked36.3150
5Locked36.390
6Locked36.340
7Locked36.620
8Locked36.620
9Locked36.6100
10Locked36.380
11Locked36.360
12Locked36.680
13Locked36.670
14Locked36.650
15Locked36.6100
16Locked37.350
17Locked37.380
18Locked37.300
19Locked36.620
20Locked36.650
21Locked36.670
22Locked36.6100
23Locked36.6100
24Locked36.680
dariusm
  • 6
Settling in
Message 6 of 10
Upstream
14620000045512064 qam1
23260000044.5512064 qam3
32580000044.8512064 qam4
43940000044.5512064 qam2
3ATDMA0000
4ATDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 10
Your >> BQM << is showing typical signs of over utilisation which is only to be expected with so many people schooling and working from home.
A good friend of the forums @Andruser has commented on the forum about similar problems to yours ...
https://community.virginmedia.com/t5/Speed/Advice-on-stats-etc/td-p/4555347/page/2
https://community.virginmedia.com/t5/Networking-and-WiFi/Poor-BQM/m-p/4557860#M365466
dariusm
  • 6
Settling in
Message 8 of 10
Configuration
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID2823898
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID2823897
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
dariusm
  • 6
Settling in
Message 9 of 10
Thanks, I feared this may be the case. I'm on a rolling contract now, so it seems my only choice it moving to a different ISP. Appreciate the feedback.
  • 17.08K
  • 731
  • 1.71K
Message 10 of 10
Change the hub to modem mode with a PC not downloading or uploading setup a new BQM and allow ICMP on windows firewall see if its any more better.
