vsbean294
Message 1 of 11
Slow speeds on PC not mobile?
Hi all,
I'm new to Virgin Media broadband, only installed 12 days ago. On the M200 package. Up to now have been getting 180-220 mbps which is amazing.
Just noticed yesterday and today, on my PC I have only been getting 2-10 mbps! On my phone it is fine but not my PC. My adapter (TP link) is up to date with latest drivers. Not sure why suddenly its has dropped? I game a lot so keen to get sorted ASAP!
Any advice would be much appreciated.
  • 5.83K
  • 481
  • 1.48K
Message 2 of 11
Re: Slow speeds on PC not mobile?
Are you testing the speed to your PC with a known good Cat 6 cable, wired directly to the Hub?  If not you need to do so, as all other speed tests are not valid.
Speed is only guaranteed wired to the Hub.
Travis_M
  • 3.28K
  • 113
  • 243
Message 3 of 11
Hi @vsbean294
Thanks for posting on our community forum!
How is your connection today? Have you tested the speeds via a Cat6 ethernet cable?
Travis_M
vsbean294
Message 4 of 11
I have no idea what at Cat6 ethernet cable is, also my router is downstairs and I can't physically move my PC towards it.
It's just weird that initially I was getting 200-220 download and now I'm getting 2. It is so slow I can't even have more than one tab open on the internet! Never had this problem before with my previous internet supplier.
Richw1982
  • 503
  • 34
  • 121
Rising star
Message 5 of 11
Hi, if its fine on your phone but the PC is slow it has to be the PC itself, or something related to.
I work for VMO2 but all opinions are my own and are based on my own experiences
vsbean294
Message 6 of 11
Well it is intermittent as well, now I am getting 90. My PC is a brand new high spec build so maybe it is the wifi on the router or adapter side of things? How do I check what it might be?
Richw1982
  • 503
  • 34
  • 121
Rising star
Message 7 of 11
Usually testing it on other devices, if other devices are getting the speed and one device isn't it can only be one thing.  Try using Cat6 ethernet to eliminate Wireless card/driver.  Could also try flushing DNS on the PC
Eeeps
  • 907
  • 57
  • 158
Well-informed
Message 8 of 11
What is the TP-Link adapter of which you speak?
I'm assuming this is a power line that connects your hub to your PC: correct?
If so you need to eliminate the possibility that it might be the problem by connecting your PC directly with an Ethernet cable to the SH3.
Then do the test.
Martin_N
  • 7.58K
  • 323
  • 474
Message 9 of 11
Hi vsbean294,
Thank you for your post. I'm very sorry to hear about the issue you're having with your broadband speeds.
I have been able to locate your account and have ran some tests and it is showing that we have identified a short term connectivity issue.
We are working to get this resolved as soon as possible.
^Martin
vsbean294
Message 10 of 11
Hi Martin,
Thank you for the reply! No worries 🙂
