hy6e
  • 15
Slow speeds and inconsistent connection
My previous post appears to have vanished! Reposting here, now with full Network log...
On 200MB and currently getting very slow speeds - anything from single figures down to a maximum of 80MBs. Speeds are VERY up and down and the connection often drops altogether.
I've done everything suggested by Virgin, but no change.
Thanks in advance for any help, logs follow...
Network LogTime Priority Description
16/10/2020 08:44:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 08:24:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 08:23:25Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 08:20:47noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 08:12:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 08:07:15Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 07:35:14noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 07:28:14noticeSW download Successful - Via Config file
16/10/2020 07:26:16noticeSW Download INIT - Via Config file
01/01/1970 00:02:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 06:34:15noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 22:54:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 22:35:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 21:41:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 21:39:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 21:18:17criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 21:06:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 20:56:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 19:18:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 19:00:10criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11390000002.438256 qam1
2147000000238256 qam2
3155000000238256 qam3
4163000000238256 qam4
51710000002.238256 qam5
61790000002.238256 qam6
7187000000238256 qam7
81950000001.740256 qam8
92030000001.538256 qam9
102110000001.738256 qam10
112190000001.538256 qam11
122270000001.538256 qam12
13235000000138256 qam13
142430000000.538256 qam14
152510000000.238256 qam15
162590000000.538256 qam16
172670000000.738256 qam17
18275000000138256 qam18
192830000001.238256 qam19
202910000001.738256 qam20
21299000000238256 qam21
22307000000240256 qam22
233150000002.540256 qam23
243230000002.540256 qam
1462000004.95512064 qam1
2258000004.85512064 qam4
3394000004.9512064 qam2
4326000004.875512064 qam3
139000000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow speeds and inconsistent connection
Please stick to one thread for your problem.
