jabster78
Slow speeds and high latency (including packet loss)
I’ve been experiencing slow speeds and high latency (including packet loss) on my M100. I’ve got a Hub3 in Modem mode and see the issues at various times of the day on both wired and wireless clients. All coax cable and connections look fine and I’ve done a full reset of the Hub3 to no avail.
The one thing I have noticed that the modulation on the upstream drops to 32/16QAM when the problem happens and based on that I started to monitor this as you can see in the graphs it fluctuates quite a bit. Power levels seem steady.
Any ideas as to what the issue might be? Hub3 and BMQ stats below.
James
 My Broadband Ping - Virgin 110
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
411000000
10
37
256 qam
1
2
419000000
9.6
37
256 qam
2
3
427000000
9.5
37
256 qam
3
4
435000000
10
37
256 qam
4
5
443000000
9.8
37
256 qam
5
6
451000000
10.3
37
256 qam
6
7
459000000
10.3
37
256 qam
7
8
467000000
10.5
37
256 qam
8
9
475000000
10.5
37
256 qam
9
10
483000000
10.9
37
256 qam
10
11
491000000
10.8
37
256 qam
11
12
499000000
10.6
37
256 qam
12
13
507000000
10.9
37
256 qam
13
14
515000000
10.8
37
256 qam
14
15
523000000
11.3
37
256 qam
15
16
531000000
11.4
37
256 qam
16
17
539000000
11.5
37
256 qam
17
18
547000000
10.9
37
256 qam
18
19
555000000
10.8
37
256 qam
19
20
563000000
10.5
37
256 qam
20
21
571000000
10.4
37
256 qam
21
22
579000000
10.9
37
256 qam
22
23
587000000
10.8
37
256 qam
23
24
595000000
11
37
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
36.6
97
8
2
Locked
37.3
132
17
3
Locked
37.3
133
15
4
Locked
37.6
66
15
5
Locked
37.3
74
14
6
Locked
37.3
80
0
7
Locked
37.6
100
14
8
Locked
37.3
86
0
9
Locked
37.6
113
15
10
Locked
37.3
51
0
11
Locked
37.3
70
0
12
Locked
37.6
87
0
13
Locked
37.3
57
16
14
Locked
37.6
76
0
15
Locked
37.6
65
0
16
Locked
37.6
56
12
17
Locked
37.6
44
0
18
Locked
37.3
96
0
19
Locked
37.6
63
0
20
Locked
37.3
60
0
21
Locked
37.3
105
0
22
Locked
37.3
50
0
23
Locked
37.6
54
0
24
Locked
37.3
46
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
33.3
5120
32 qam
6
2
46200000
33.8
5120
32 qam
5
3
25800000
33.5
5120
16 qam
8
4
32600000
33.5
5120
16 qam
7
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
4
0
4
ATDMA
0
0
0
0
jabster78
Re: Slow speeds and high latency (including packet loss)
Time
Priority
Description
07/02/2021 22:53:2
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38
critical
04/02/2021 13:18:37
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/02/2021 07:31:1
Error
03/02/2021 10:01:43
critical
01/02/2021 15:25:1
Error
27/01/2021 19:47:21
notice
27/01/2021 19:45:33
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 10:36:58
Error
26/01/2021 00:48:9
critical
24/01/2021 06:55:33
Error
23/01/2021 10:36:15
critical
21/01/2021 12:36:18
notice
20/01/2021 11:02:1
critical
20/01/2021 01:18:18
Error
16/01/2021 19:32:45
critical
16/01/2021 13:18:18
Error
14/01/2021 12:46:53
critical
13/01/2021 01:18:17
Error
12/01/2021 14:02:16
critical
