Charlie2005
Message 1 of 5
Slow speeds and drop outs
For the last couple of weeks o have noticed a huge drop in my speeds and connection loss regular, both I and my husband  are working from home too, when we ate streaming its stop start, stop start and then freezes and drops out altogether which is getting extremely frustrating 😑  we have the m350 broadband and I am lucky most of the time if my download speed reaches 17mbs and upload reaches 16mbs, so please help
jpeg1
  • 5.43K
  • 284
  • 895
Superstar
Message 2 of 5
Re: Slow speeds and drop outs
Are you both using WiFi ? If so, try a test with a laptop or PC connected to the Hub with an ethernet cable. This will help to establish where the problem is.
Charlie2005
Message 3 of 5
Yes we both are working from laptops, connected to hub with cable and still low speeds
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 5
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 5
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
A Guru will be along soon to decipher the info
