11-08-2023 09:40 - edited 11-08-2023 09:44
I'm getting slow internet speeds (I'm confident it's not a Virgin issue)
Specs and things tried:
I'm at a loss of what to try next, and help would be appreciated.
Below is my speed test, I'm getting the correct speed to the modem then nearly half out my PC.
It seemed to start having this issue when I installed MSI Lan manager, it screwed up my speed, I uninstalled it afterwards but my speed has still been rubbish!
Thanks.
on 11-08-2023 13:38
Share the Full Test results from Realspeed so we get to see the Upstream figures for the Hub and the device.
Re-try the Realspeed test with the computer booted in Safe Mode + Networking, often the results improve by a decent amount.
14-08-2023 11:37 - edited 14-08-2023 11:37
Upstream is fine I get 108mb, its just the downstream,
on 14-08-2023 12:07
Hi CraigT1976,
Thank you for reaching back out, please can you share your share your full test results as requested so we can look further into this for you?
Paul.
on 15-08-2023 10:36
on 15-08-2023 11:29
Hi Craig,
From the speed test result there doesn't seem to be an issue, the correct speed is hitting the Router.
Paul.
on 15-08-2023 22:08
I know, that's why I said I'm confident it's not a virgin issue, it's an issue with my PC, but can't figure out what though.
on 15-08-2023 22:18
Did you try safe mode with networking, as suggested above?
https://www.bleepingcomputer.com/tutorials/how-to-start-windows-10-in-safe-mode-with-networking/
