Duffman1
  • 10
Message 1 of 14
Slow speed
Speeds on Hub 3 dropped off dramatically about a week ago. Have tried all the usual trouble shooting. I’m on the 200Mbps service but getting <10 download speeds on devices in same room as Hub, even when I test with Ethernet connection. Hub is well positioned as per all the guidance. Have reset it but made no difference.  Any help gratefully received!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 14
Re: Slow speed
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 14
Re: Slow speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 14
Re: Slow speed
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Duffman1
  • 10
Message 5 of 14
Re: Slow speed
Hello, thanks fo responding.
Samknows: did three tests with Ethernet from my Mac straight to hub
1) Latency 19.0, Jitter 6.00, Download 197 and Upload 17.1
2) Latency 20.1, Jitter 4.10, Download 70.0 and Upload 16.9
3) Latency 20.2, Jitter 4.20, Download 203 and Upload 15.1
Hub settings: I refreshed immediately after and it says speed from same device is 1000Mbps.
Duffman1
  • 10
Message 6 of 14
Re: Slow speed
My BQM
Duffman1
  • 10
Message 7 of 14
Re: Slow speed
Downstream
1331000000-5.238256 qam25
2203000000-5.537256 qam9
3211000000-6.237256 qam10
4219000000-6.528256 qam11
5227000000-6.229256 qam12
6235000000-637256 qam13
7243000000-6.237256 qam14
8251000000-5.537256 qam15
9259000000-5.538256 qam16
10267000000-637256 qam17
11275000000-5.538256 qam18
12283000000-5.238256 qam19
13291000000-5.538256 qam20
14299000000-5.238256 qam21
15307000000-4.738256 qam22
16315000000-4.238256 qam23
17323000000-4.738256 qam24
18339000000-4.538256 qam26
19347000000-4.238256 qam27
20355000000-538256 qam28
21363000000-538256 qam29
22371000000-538256 qam30
23379000000-538256 qam31
24387000000-5.538256 qam32
1Locked38.62930
2Locked37.3275389
3Locked37.64690147
4Locked28.61129737036474891563
5Locked29571575981274554922
6Locked37.619970
7Locked37.6161212
8Locked37.39220
9Locked38.65930
10Locked37.69285
11Locked38.65960
12Locked38.62800
13Locked38.64381
14Locked38.656416
15Locked38.61840
16Locked38.61460
17Locked38.61720
18Locked38.63050
19Locked38.91990
20Locked38.61880
21Locked38.62670
22Locked38.92610
23Locked38.93050
24Locked38.93415734
Duffman1
  • 10
Message 8 of 14
Re: Slow speed
15370000957512064 qam2
Duffman1
  • 10
Message 9 of 14
Re: Slow speed
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
sgvca69834ncxv9873254k;fg87ds
SFID26089
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Duffman1
  • 10
Message 10 of 14
Re: Slow speed
11/01/2021 09:49:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:49:5Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:48:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:48:53Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:48:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:48:41Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:48:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:47:55Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:47:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:47:41Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:47:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:47:7Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:45:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:45:11Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:45:10Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:45:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:45:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:44:49Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:44:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 09:44:31Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
