Leew1983
Slow speed
Supposed to get up to 200mps but only getting in the 40’s and 20’s at peak times. Wired and wireless. Rebooted on numerous occasions
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow speed
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow speed
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
BenWeimy
Re: Slow speed
Standard automated response, which requires that customer to do more?!  I hope you're not a VM employee and just a helpful citizen so that VM don't look irresponsible and uncaring.
Just so tired of VM's poor customer service.
conman33158
  • 1.56K
  • 131
  • 295
Super solver
Re: Slow speed
I can assure you MikeRobbo is not automated. It's the start of the process to figure out way you're getting the speed issues bud 🙂
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow speed
Not a problem to me, my 500Mbs is working perfectly so TBH I don't really care what state your broadband is in.
That is me bugging out from this thread.
