  • 6
Message 1 of 8
Slow speed
I have recently moved to Virgin for my TV, Phone & broadband. I have M200 fibre package. The line speed on the TV & Hub is operating at 585Mps but when I run a speed test it only registers 30Mps for the majority of the time but occasionally increases to around 140 Mps for a few minutes. Is this normal?
  • 12.3K
  • 952
  • 1.58K
Message 2 of 8
Re: Slow speed
What speed do you get at >>  speedtest.net  << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 6
Message 3 of 8
Re: Slow speed
Speed when connecting with the cable supplied was around 40Mps. I have just reset the hub and the speed improved to around 180Mps on both cable and WiFi. Stayed there for around 30 mins then dropped back to around the 40Mps mark. Still puzzled. Tried to contact support on 2 occasions, left hanging for around 1 hour so gave up!
  • 12.3K
  • 952
  • 1.58K
Message 4 of 8
Re: Slow speed
Then
Can you please
Mike Robinson
  • 6
Message 5 of 8
Re: Slow speed
Can you please send a screen shot for location of Link icon. Cannot find?
  • 6
Message 6 of 8
Re: Slow speed
https://www.thinkbroadband.com/broadband/monitoring/quality/share/2c155b52bf68cf0a3276ea4f76226d1e90...
12507500004.840256 qam15
21387500004.938256 qam1
31467500004.540256 qam2
41547500004.140256 qam3
51627500004.140256 qam4
61707500004.340256 qam5
7178750000440256 qam6
81867500004.140256 qam7
9194750000440256 qam8
10202750000440256 qam9
112107500004.340256 qam10
122187500004.540256 qam11
132267500004.640256 qam12
142347500004.840256 qam13
152427500004.640256 qam14
162587500004.640256 qam16
172667500004.940256 qam17
18274750000540256 qam18
192827500005.340256 qam19
202907500005.340256 qam20
212987500005.540256 qam21
223067500004.840256 qam22
233147500004.940256 qam23
243227500005.140256 qam24
1Locked40.350
2Locked38.950
3Locked40.390
4Locked40.340
5Locked40.3190
6Locked40.3150
7Locked40.9180
8Locked40.3160
9Locked40.3200
10Locked40.9210
11Locked40.360
12Locked40.340
13Locked40.350
14Locked40.360
15Locked40.340
16Locked40.950
17Locked40.360
18Locked40.360
19Locked40.960
20Locked40.370
21Locked39.350
22Locked40.970
23Locked40.940
24Locked40.360
1326000075.175512016 qam3
2536999985.175512016 qam5
3258000075.175512016 qam4
4394000005.175512016 qam2
3ATDMA0000
4ATDMA0000
  • 6
Message 7 of 8
Re: Slow speed
23/10/2020 09:22:23noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 06:17:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 19:54:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 19:33:22noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 19:33:22ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 19:20:22ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 19:18:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 19:07:23ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 17:54:56noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 17:44:48ErrorService Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 00:48:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 22:13:24noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 22:00:34Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 14:58:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 14:58:14Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 14:58:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 14:58:9criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 14:58:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 14:44:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 6
Message 8 of 8
Re: Slow speed
Just identified that there was a fault on the system yesterday which was rectified by an Engineer. Since I have reset the Hub 3. The download speeds are now great. Have run a number of speed tests and all show >140 Mps. So looking a lot better. Thanks for the support.
