wayneold
  • 27
Message 1 of 13
Slow speed
Internet has been unbearable for 2 weeks now, paying for 350mb and lucky to get 15mb
virgin say the usual switch off and reboot and admit the signal speed is low but won’t do anything? The worse customer service in the uk in my opinion, they really don’t be the £690 a year they are charging
shocking service
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 13
Re: Slow speed
How are you connecting your device[s], Wi-Fi or ethernet cable ?
wayneold
  • 27
Message 3 of 13
Re: Slow speed
Both, but as most devices are wireless it’s very frustrating. iPads, phones are quicker in their SIM cards
ive read their Hub 3 is terrible, is it time to upgrade a router and put it in modem mode? I begrudge spending £200 to fix an issue that’s costing me £57.50 a month as it is though unless it will really help
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 13
Re: Slow speed
Forget Wi-Fi until the status of the Broadband connection can be determined.
What speed do you get using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
wayneold
  • 27
Message 5 of 13
Re: Slow speed
If I disconnect every device on WiFi and connect my laptop on its own it will get between 200-300mb depending on time of day
issue is every other device on WiFi, iPads, tv etc. You can be sat 1 foot away from the hub 3 and the connection will disconnect. Virgin online chat have said they can see issues and I should disable 5G, I’m paying for the 350mb package so this seems a strange request from them rather than trying to fix any issues?
I have a net gear booster upstairs and this works fine for devices which are further away...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 13
Re: Slow speed
So from that I take it the Broadband connection is poor but not unusable until the Wi-Fi items are connected ?
The problem with the Wi-Fi is that there is only so much of it to be shared out and then it is open to interference.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
wayneold
  • 27
Message 7 of 13
Re: Slow speed
Speeds can drop that slow on WiFi the tv in the same room can’t buffer Netflix or youtube
this is the 2nd hub3 now as they said the last one had bust. It’s very frustrating, if the speeds are so slow I’m wasting money subscribing to the top package
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 13
Re: Slow speed
Wi-Fi streaming devices will be sucking the life out of the wireless broadcast, can you connect the TV or TV Box using an ethernet cable ?
wayneold
  • 27
Message 9 of 13
Re: Slow speed
No, unfortunately not. I regret not having cat5 etc installed through the house when it was rewired now 😞
ah well, think I’ll try BT if this doesn’t improve, got nothing to lose..
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 13
Re: Slow speed
Many people have accepted that the VM Wi-Fi is poor and have purchased third party equipment that is much, much more powerful than the VM supplied kit and once set up have wondered why they waited for so long.
