mlahage
Slow speed
VM installed on Monday 7/09/20
Paid for 362, getting sub-80 mbps upload throughout day, multiple devices, worst on laptops. Plugging into router only slightly better.
I scanned every room on the app, including the room that my laptop and router is in, and got "Great" for relevant rooms.
When I got to the desktop Hub 3 site, I get "Problem with your Wifi"
From Hub3
Acquired Downstream Channel (Hz) 331000000 Locked
Ranged Upstream Channel (Hz) 46200172 Locked
Provisioning State Online
downstream
1 331000000 3.9 38 256 qam 25
2 203000000 4.5 38 256 qam 9
3 211000000 4.5 38 256 qam 10
4 219000000 4.1 38 256 qam 11
5 227000000 4 38 256 qam 12
6 235000000 3.7 38 256 qam 13
7 243000000 4 38 256 qam 14
8 251000000 4 38 256 qam 15
9 259000000 4.5 38 256 qam 16
10 267000000 4.1 38 256 qam 17
11 275000000 4.3 38 256 qam 18
12 283000000 4.1 38 256 qam 19
13 291000000 4.5 38 256 qam 20
14 299000000 4.4 38 256 qam 21
15 307000000 4.5 40 256 qam 22
16 315000000 4 38 256 qam 23
17 323000000 4.4 38 256 qam 24
18 339000000 4 38 256 qam 26
19 347000000 3.5 38 256 qam 27
20 355000000 3.9 38 256 qam 28
21 363000000 4 38 256 qam 29
22 371000000 4.9 38 256 qam 30
23 379000000 4.6 38 256 qam 31
24 387000000 5.3 38 256 qam 32
1 Locked 38.9 1 0
2 Locked 38.9 4 0
3 Locked 38.9 5 0
4 Locked 38.9 6 0
5 Locked 38.6 5 0
6 Locked 38.9 0 0
7 Locked 38.9 6 0
8 Locked 38.6 1 0
9 Locked 38.9 5 0
10 Locked 38.9 2 0
11 Locked 38.9 5 0
12 Locked 38.9 6 0
13 Locked 38.9 5 0
14 Locked 38.9 6 0
15 Locked 40.3 5 0
16 Locked 38.9 0 0
17 Locked 38.9 8 0
18 Locked 38.6 7 0
19 Locked 38.9 2 0
20 Locked 38.9 5 0
21 Locked 38.9 1 0
22 Locked 38.9 0 0
23 Locked 38.9 0 0
24 Locked 38.9 0 0
upstream
1 46200172 4.725 5120 32 qam 3
2 53699857 4.725 5120 32 qam 2
3 39399882 4.675 5120 32 qam 4
4 60300096 4.775 5120 32 qam 1
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
network
10/09/2020 14:27:30 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
From speedtest
IP_ADDRESS TEST_DATE TIME_ZONE DOWNLOAD_MEGABITS UPLOAD_MEGABITS LATENCY_MS SERVER_NAME DISTANCE_MILES CONNECTION_MODE SERVER_COUNT
[REMOVED] 9/10/20 13:36 GMT 87.74 7.81 19 London 0 multi 4
[REMOVED] 9/10/20 13:37 GMT 97.81 14.51 13 London 0 multi 4
[REMOVED] 9/10/20 13:44 GMT 82.49 14.64 12 London 0 multi 4
[REMOVED] 9/10/20 13:46 GMT 101.26 11.37 14 London 0 multi 4
[REMOVED] 9/10/20 13:47 GMT 97.13 12.58 12 London 0 multi 4
[REMOVED] 9/10/20 13:49 GMT 71.94 16.14 14 London 0 multi 4
[REMOVED] 9/10/20 14:18 GMT 61.16 21.14 16 London 0 multi 4
[REMOVED] 9/10/20 14:48 GMT 64.98 14.5 16 London 0 multi 4
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow speed
Are those speed test results from using a Wi-Fi connection or ethernet cable connection ?
If they are Wi-Fi tests what is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
mlahage
Re: Slow speed
Thanks for your quick message. I tried Cat cable earlier today as well, the difference in speed ranged from zero to +7 mbps, so not a meaningful difference.
I just disconnected everything else, no other devices connected, and connected via cable
[MOD EDIT: IP Removed] 9/10/20 18:42 GMT 13.39 22.74 15 London 0 multi 4
[MOD EDIT: IP Removed] 9/10/20 18:43 GMT 9.35 20.3 14 London 0 multi 4
[MOD EDIT: IP Removed] 9/10/20 18:58 GMT 16.06 24.22 14 London 0 multi 4
[MOD EDIT: IP Removed] 9/10/20 18:59 GMT 13.48 25.23 13 London 0 multi 4
[MOD EDIT: IP Removed] 9/10/20 19:00 GMT 20.66 25.36 14 London 0 multi 4
