baresi
Slow speed
I have 100 mbs package but at times this dips to anywhere between 2 and 90 mbs. It is also throwing devices such as Alexa Echo and Sonos beam out of the internet. Here are the logs from my router. Any advice?
Refresh data
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
5.6
38
256 qam
25
2
203000000
4.8
38
256 qam
9
3
211000000
4.9
38
256 qam
10
4
219000000
5
38
256 qam
11
5
227000000
5
38
256 qam
12
6
235000000
5
38
256 qam
13
7
243000000
5
38
256 qam
14
8
251000000
5
38
256 qam
15
9
259000000
5.1
38
256 qam
16
10
267000000
5.1
38
256 qam
17
11
275000000
5.1
38
256 qam
18
12
283000000
5.4
38
256 qam
19
13
291000000
5.5
38
256 qam
20
14
299000000
5.8
38
256 qam
21
15
307000000
5.6
38
256 qam
22
16
315000000
5.6
38
256 qam
23
17
323000000
5.5
38
256 qam
24
18
339000000
5.6
38
256 qam
26
19
347000000
5.5
38
256 qam
27
20
355000000
5.5
38
256 qam
28
21
363000000
5.5
38
256 qam
29
22
371000000
5.9
38
256 qam
30
23
379000000
6
38
256 qam
31
24
387000000
6
38
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
647
5090
2
Locked
38.9
738
7764
3
Locked
38.6
145
5165
4
Locked
38.9
116
299
5
Locked
38.9
95
4728
6
Locked
38.9
131
6880
7
Locked
38.6
115
279
8
Locked
38.9
167
6320
9
Locked
38.9
123
275
10
Locked
38.6
84
5912
11
Locked
38.9
139
5056
12
Locked
38.9
1359
5369
13
Locked
38.9
969
5396
14
Locked
38.9
650
4605
15
Locked
38.9
569
4355
16
Locked
38.6
624
4525
17
Locked
38.9
661
4298
18
Locked
38.6
618
4395
19
Locked
38.9
690
4201
20
Locked
38.6
638
4485
21
Locked
38.6
670
4452
22
Locked
38.9
636
4227
23
Locked
38.6
632
4520
24
Locked
38.9
631
2682
Refresh data
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
4.475
5120
64 qam
4
2
46200000
4.55
5120
64 qam
3
3
53700000
4.55
5120
64 qam
2
4
60300000
4.575
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Refresh data
Time
Priority
Description
05/08/2020 12:59:45
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/08/2020 00:55:41
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 11:28:20
critical
31/07/2020 19:06:28
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 19:06:28
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 07:58:30
Error
31/07/2020 05:45:10
critical
30/07/2020 20:50:36
Error
27/07/2020 12:14:21
critical
27/07/2020 11:12:40
notice
27/07/2020 11:12:40
Error
26/07/2020 20:55:55
Error
26/07/2020 14:05:47
critical
26/07/2020 06:39:15
Error
23/07/2020 09:52:3
critical
21/07/2020 21:56:59
notice
21/07/2020 21:56:59
Error
21/07/2020 00:35:3
Error
18/07/2020 11:55:16
critical
17/07/2020 18:14:52
notice
  • 22.35K
  • 2.4K
  • 3.99K
Re: Slow speed
Stats look ok. The postRS errors might be a concern so to check, reboot the Hub and check the counts all reset to 0. Then look every hour or two for a couple of days and see if they reappear - they shouldnt.
First do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any splitters/attenuators/etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box.
Then do a Hub “pinhole reset” - disconnect any ethernet cables and with the Hub "switched on" throughout, press pin in firmly with paper clip/SIM tray tool and hold it there for 60 seconds – release the pin then leave it 10’ to stabilise. But, make sure the 2 passwords on the Hub sticker are still there and legible first !
Also, in the meantime, (if you haven’t already) set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” when you have the first 24h period.
