Ecotecheating
  • 5
Message 1 of 10
Slow speed
Really struggling with slow speed. Less than 20 meg most days. I’m on 100 meg package. This is both WiFi and Ethernet. I reboot the rooter and it’s ok for a couple of days and then it’s down to a crawl again. Cannot find an email address to contact virgin and all phone lines busy due to covid.
gary_dexter
  • 30.51K
  • 1.89K
  • 4.05K
Message 2 of 10
Re: Slow speed
What speeds do you get wired and with what cable type?
-tony-
  • 16.54K
  • 1.31K
  • 3.9K
Message 3 of 10
Re: Slow speed
OP says 20meg wired and wifi - cable typs should not matter on 100meg
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
Ecotecheating
  • 5
Message 4 of 10
Re: Slow speed
These are the stats you wanted  Ethernet cable is ok as I get 109 meg after rebooting hub
Edit. The pictures don’t appear to have uploaded. I’ll try again.  
gary_dexter
  • 30.51K
  • 1.89K
  • 4.05K
Message 5 of 10
Re: Slow speed
So wired is getting full speeds?
Ecotecheating
  • 5
Message 6 of 10
Re: Slow speed
Wired and WiFi get full speed after reboot. But then both drop to a crawl after a day or so. No difference in speed between wired and WiFi.
Ecotecheating
  • 5
Message 7 of 10
Re: Slow speed
gary_dexter
  • 30.51K
  • 1.89K
  • 4.05K
Message 8 of 10
Re: Slow speed
What hub do you have?
David_Bn
  • 4.93K
  • 226
  • 402
Message 9 of 10
Re: Slow speed
Thanks for you post Ecotecheating, and a very warm welcome to you!
I've been able to look at the stats of the hub and everything appears to be in spec.
I can see that the hub has an uptime of 21 days. Can you please perform a reboot and monitor the connection.
If this is still a problem, please perform a pin hole reset on the hub and then go through a monitoring period again for me
David_Bn
Ecotecheating
  • 5
Message 10 of 10
Re: Slow speed
Thanks for your help. I’ll reboot it again and see how it goes. If it still plays up I’ll try the pinhole reset.
