Cco7ran
  • 10
Message 1 of 20
Slow speed
Area 28 M500 Extremely slow download normally 550 mb currently experiencing 35 mb max , Ethernet connected tried on various devices , upload speed fine and ping seems normal but download speed been slow since 0530 this morning now it’s 1100 , restarted and reset router still the same , service status shows no problems in area , help
John_GS
  • 8.71K
  • 476
  • 769
Message 2 of 20
Re: Slow speed
Hi Cco7ran
Thanks for posting and welcome to the community. I am sorry to hear of the lower than expected speeds. I've ran a check and cannot see any issues on the system that could be causing this. Has the speed issue been fixed since posting? Let me know if you need further help.
Kind regards,
John_GS
Cco7ran
  • 10
Message 3 of 20
Re: Slow speed
No and according to neighbours and local Facebook group we are all experiencing slow speeds , so it’s not my equipment , I chose virgin because of the reliable speeds but this slow speed is unworkable and has been like this for 3 days and if I’m correct I’m entitled to cancel because your not supplying the slowest permissible speed , I’ve called helpline and told to reset router several times unplugged everything apart from my main pc and turned off WiFi still the same I know it’s not my set up if others in my area are having issues too my ping is same as normal and upload speed is ok it’s just download which currently according to Speedtest.net I’m getting 25mb instead of 550mb , if you where aware of issues due to whatever reasons , fine , it’s the fact your sticking your  head in the sand and saying there is no problem
John_GS
  • 8.71K
  • 476
  • 769
Message 4 of 20
Re: Slow speed
I am sorry to hear you're having issues still. As I say, from checking the system, no issues are showing.
Can you run a wired PC/Laptop test with just that connected via Ethernet for me, at speedtest.net and let me know the result?
Kind regards,
John_GS
Cco7ran
  • 10
Message 5 of 20
Re: Slow speed
ping 9 download 43.41 upload 37.28
Cco7ran
  • 10
Message 6 of 20
Re: Slow speed
Second test
ping 10 download 26.17 upload 37.21
gary_dexter
  • 30.44K
  • 1.88K
  • 4.04K
Message 7 of 20
Re: Slow speed
Are you wired directly to the hub and not via a powerline adaptor or switch etc?
Cco7ran
  • 10
Message 8 of 20
Re: Slow speed
Cat 6 cable about 3 feet from pc , only thing plugged in hub
John_GS
  • 8.71K
  • 476
  • 769
Message 9 of 20
Re: Slow speed
Does the device you're testing the speed on have a Gigabit NIC card?
To find this out, please follow the below;
  • Click Start
  • Type Device Manager into the search bar
  • Click Device Manager from the list
  • Expand Network adapters
  • If you have a Gigabit NIC it will be labeled as Gigabit.
If it is and to ensure it's configured correctly, please do the below;
  • Right click on the NIC in the Device Manager
  • Click on Properties
  • In Properties, click on the Advanced tab
  • In Advanced select Speed & Duplex and check the setting in Type
  • Setting the Type to Auto or Auto Negotiation should allow the NIC to connect at the fastest available rate
Kind regards,
John_GS
Cco7ran
  • 10
Message 10 of 20
Re: Slow speed
Of course ! Otherwise I wouldn’t have been getting 550mb the other day , would I , Xbox one x and PS4 pro all have gigabit ports too tested on my sons gaming pc too , I’ve exhausted all avenues it’s not my equipment  it’s the supply
