Jon_M84
  • 11
Message 1 of 7
Slow speed on M200
Experiencing slow download speeds during the day, (max 40mbps but usually around 5-10mbps). Seems to resolve itself after rebooting my Hub4 but then 20 mins later slow again!
Spent nearly 1hr on hold with VM and still cannot get through to someone
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 7
Re: Slow speed on M200
Is that on an ethernet cable or Wi-Fi connection ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 7
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 7
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Jon_M84
  • 11
Message 5 of 7
3.0 Downstream channels
10 211000000 3.099998 38.605377 QAM256 10
1 139000000 3.200001 37.636276 QAM256 1
2 147000000 3.200001 38.605377 QAM256 2
3 155000000 3.099998 38.605377 QAM256 3
4 163000000 3.200001 38.605377 QAM256 4
5 171000000 3.099998 38.983261 QAM256 5
6 179000000 3.200001 38.605377 QAM256 6
7 187000000 3.200001 38.605377 QAM256 7
8 195000000 3.200001 38.605377 QAM256 8
9 203000000 3.099998 37.636276 QAM256 9
11 219000000 2.799999 37.636276 QAM256 11
12 227000000 2.799999 37.636276 QAM256 12
13 235000000 2.700001 37.636276 QAM256 13
14 243000000 2.599998 38.605377 QAM256 14
15 251000000 2.400002 37.636276 QAM256 15
16 259000000 2.200001 37.355988 QAM256 16
17 267000000 2.400002 37.636276 QAM256 17
18 275000000 2.700001 37.636276 QAM256 18
19 283000000 2.099998 37.636276 QAM256 19
20 291000000 1.700001 37.636276 QAM256 20
21 299000000 1.000000 37.355988 QAM256 21
22 307000000 0.900002 37.636276 QAM256 22
23 315000000 1.000000 37.355988 QAM256 23
24 323000000 1.299999 37.355988 QAM256 24
25 443000000 1.400002 37.636276 QAM256 25
26 451000000 1.500000 37.355988 QAM256 26
27 459000000 1.400002 37.636276 QAM256 27
28 467000000 1.400002 37.636276 QAM256 28
29 475000000 1.700001 37.636276 QAM256 29
30 483000000 1.799999 37.636276 QAM256 30
31 491000000 1.799999 37.636276 QAM256 31
10 Locked 0 0 0
1 Locked 4101372 0 0
2 Locked 3858062 0 0
3 Locked 4778843 0 0
4 Locked 5170336 0 0
5 Locked 4452064 0 0
6 Locked 5002298 0 0
7 Locked 72229923 0 0
8 Locked 1501804 0 0
9 Locked 1724605 0 0
11 Locked 2023011 0 0
12 Locked 1340595 0 0
13 Locked 1331072 0 0
14 Locked 852215 0 0
15 Locked 1598296 0 0
16 Locked 1183581 0 0
17 Locked 1403389 0 0
18 Locked 1449706 0 0
19 Locked 1376582 0 0
20 Locked 1217323 0 0
21 Locked 1353739 0 0
22 Locked 1358081 0 0
23 Locked 1345985 0 0
24 Locked 7590277 0 0
25 Locked 9544082 0 0
26 Locked 7538759 0 0
27 Locked 8783490 0 0
28 Locked 76551964 0 0
29 Locked 9225164 0 0
30 Locked 8364000 0 0
31 Locked 75398819 0 0
3.1 Downstream channels
33 96 4K 1880 QAM4096 728
33 Locked -0.6 1156267 0
3.0 Upstream channels
1 39400000 33.020599 5120 KSym/sec 64QAM 2
2 46200000 33.020599 5120 KSym/sec 64QAM 1
3 25800000 33.270599 5120 KSym/sec 64QAM 4
4 32600000 33.270599 5120 KSym/sec 64QAM 3
1 US_TYPE_STDMA 0 0 1 0
2 US_TYPE_STDMA 0 0 1 0
3 US_TYPE_STDMA 0 0 1 0
4 US_TYPE_STDMA 0 0 1 0
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt060+voc-b.cm
SFID
156456
Max Traffic Rate
230000061
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
156455
Max Traffic Rate
22000061
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
Sat 14/11/2020 16:48:01 6 CM-STATUS message sent. Event Type Code: 21; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 16:48:01 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 16:50:58 3 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 16:56:30 4 Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 16:57:12 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 17:00:07 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:18 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 17:16:42 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 17:26:29 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 17:26:32 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 17:26:34 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 17:26:34 6 CM-STATUS message sent. Event Type Code: 23; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 17:26:45 6 CM-STATUS message sent. Event Type Code: 4; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 14/11/2020 18:10:21 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 15/11/2020 12:56:55 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 15/11/2020 13:21:20 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 15/11/2020 13:21:42 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:16 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 15/11/2020 13:51:44 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 18/11/2020 05:35:09 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 18/11/2020 16:00:51 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 21/11/2020 14:27:33 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 23/11/2020 10:48:46 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 25/11/2020 09:18:03 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 26/11/2020 07:54:49 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:43 5 ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:00:21 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:00:31 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:00:48 4 ToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:00:53 6 CM-STATUS message sent. Event Type Code: 4; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:13 4 ToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:44 5 ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:00:29 5 ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:00:57 4 ToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 02/01/1970 16:32:22 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 02/01/1970 16:33:29 4 ToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 03/01/1970 20:42:05 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 03/01/1970 20:43:21 4 ToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:19 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 01/12/2020 08:55:38 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:17 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 01/12/2020 17:21:55 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 01/12/2020 17:22:05 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 01/12/2020 17:22:29 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Jon_M84
  • 11
Message 6 of 7
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 7
@Jon_M84 wrote:
My BQM
BQM needs to run before any kind of trend starts to show.
Your Downstream Power Levels individually are all within spec but, the differential between the lowest at -0.6dBmV and the highest at +3.2dBmv is too great.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
