StuTibs
Slow speed in Woking Area
Crazy slow speeds in Woking
Should be 200mbps getting just about 20mbps. Been like it a few days now
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow speed in Woking Area
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
