  • 38
Message 1 of 42
Slow speed but on M200
On wired pc but only getting 80 mbps download
  • 17.48K
  • 1.84K
  • 3.05K
Message 2 of 42
Re: Slow speed but on M200
Does the pc only have a 10/100 NIC card?
Or is it being limited to that in its settings - are the drivers up to date?
Are you using a new Cat5e/6 cable?
Are you testing on a VM server at speedtest.net?
Have you tried different browsers?
Try it again booted into safe + networking mode.
  • 38
Message 3 of 42
Does the pc only have a 10/100 NIC card? no its 1 GB
Or is it being limited to that in its settings - are the drivers up to date? yes
Are you using a new Cat5e/6 cable? Cat 6
Are you testing on a VM server at speedtest.net? yes
Have you tried different browsers? yes
still nothing
  • 17.48K
  • 1.84K
  • 3.05K
Message 4 of 42
If you are only getting ~80 mbps in safe+networking mode - then the obvious reason is that your NIC card is not working at 1GB - for whatever reason.
However, as you say it is, one other possiibilty is - were you on a lower package and been recently upgraded to 200?
If so, the upgrade configuration file may not have been sent to your Hub. You can look in the "Max Data Rate" boxes in the configuration file in your Hub settings to see what the settings are.
Or, whats your upload speed like - it should be around 20mbps on the 200 package.
  • 38
Message 5 of 42
theres no max data rate
  • 17.48K
  • 1.84K
  • 3.05K
Message 6 of 42
Do you mean its set to zero - or you just cant find it ?  I assume the latter!  You didnt say what Hub model you have so I cant tell you exactly where to look.....  but on my SH2 the data is here............
  • 38
Message 7 of 42
  • 38
Message 8 of 42
Max Traffic Rate230000061
Max Traffic Rate22000061
  • 17.48K
  • 1.84K
  • 3.05K
Message 9 of 42
OK you are set up OK.
I still think it most likely there's an issue on your wired PC - I am Mac only so cant suggest anything else Windoze related.
I would try a new ethernet cable first. Maybe get a cheap 1GB USB3-Ethernet adapter to bypass the NIC card/driver and see if that helps.
Also get a 1GB USB3 5GHz wifi dongle and see if wifi speeds are better.
Then (if you dont have one), ask a friend with a known GB enabled laptop to drop in and test their device wired and wifi on your connection.
  • 38
Message 10 of 42
what sort of issue?
