dsmuk
  • 16
Slow speed broadband
Keep getting poor speed on my 200mb connection on my Superhub 3 tried rebooting and resetting it made no difference get anywhere between 20-100mb have run your status service checks aswell.
  • 6.08K
  • 511
  • 1.57K
Re: Slow speed broadband
Is this wired or wireless ?  Have you done a speed test wired directly to the Hub with a known good Cat 6a cable?
Ashleigh_C
  • 4.1K
  • 162
  • 310
Hi there @dsmuk
Thank you so much for your post and I am so sorry to hear that you are facing these issues with your connection.
Are you able to confirm if this is across a wired or wireless connection? As @Adduxi has suggested are you able to conduct a wired test for us at all?
Thank you.
Ash_C
