Shootster
Slow speed and loss of connection
45 minutes to get through to customer service, who tell you that you have an internal problem, when you haven’t done or changed anything when you had over 100mb before, then an engineer comes out and fiddles with the cable connections and all sorted now...and again for the third time in a week my connection is running at twenty Meg..laughable really but very annoying, especially when your working from home, if you have a problem outside, don’t blame Olie on us and make excuses, when you can’t deliver what you promise, VIRGIN MEDIA!!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow speed and loss of connection
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
