sumarz
Slow speed and connection drop
Are there individuals in the HA7 area who are having internet issues their speed dropping to 20mbps for a while and line totally disconnecting and then back up again and it is very sporadic
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow speed and connection drop
Try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
