smartie-02
Message 1 of 5
Slow speed and Volt has made no difference
On Volt M200 Fibre
Latest speedtest below (consistent at this speed)
PING ms 18  DOWNLOAD Mbps 20.24  UPLOAD Mbps 21.23
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
266750000
-1.7
38
256 qam
17
2
138750000
-3.2
38
256 qam
1
3
146750000
-3.2
38
256 qam
2
4
154750000
-2.7
38
256 qam
3
5
162750000
-2.2
38
256 qam
4
6
170750000
-2
38
256 qam
5
7
178750000
-1.7
38
256 qam
6
8
186750000
-1.5
38
256 qam
7
9
194750000
-1.9
38
256 qam
8
10
202750000
-1.7
38
256 qam
9
11
210750000
-1.7
38
256 qam
10
12
218750000
-1.5
38
256 qam
11
13
226750000
-1.5
38
256 qam
12
14
234750000
-1.5
38
256 qam
13
15
242750000
-1.7
38
256 qam
14
16
250750000
-1.5
38
256 qam
15
17
258750000
-1.5
38
256 qam
16
18
274750000
-2
38
256 qam
18
19
282750000
-2.2
38
256 qam
19
20
290750000
-1.9
38
256 qam
20
21
298750000
-1.5
38
256 qam
21
22
306750000
-1.2
38
256 qam
22
23
314750000
-0.9
40
256 qam
23
24
322750000
-0.4
38
256 qam
24
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400096
46.5
5120
64 qam
3
2
32599922
45.8
5120
64 qam
4
3
46200000
46.8
5120
64 qam
2
4
53700069
48
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
2
0
3
ATDMA
0
0
1
0
4
ATDMA
0
0
0
0
Time
Priority
Description
24/11/2021 10:55:48
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2021 05:21:47
critical
24/11/2021 03:52:33
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2021 06:33:28
critical
21/11/2021 20:55:14
notice
  • 33.55K
  • 3.29K
  • 6.37K
Message 2 of 5
Re: Slow speed and Volt has made no difference
You are missing a table of Down data - RSErrors.
Can you try a speedtest this way.
-___________________________-
As you expect >100Mbps then connect a 1GB enabled computer/laptop, with up to date drivers, via a NEW and working Cat5e/6a ethernet cable, directly to the Hub which you have put into “modem mode” (https://www.virginmedia.com/help/virgin-media-hub-modem-mode ). This ensures that NO other devices are connected
Test speeds at https://speedtest.samknows.com/ - try on 2 different browsers.
If they are still low – boot your device into Windows safe+networking mode - to disable any potentially interfering software - and try again.
There are many posts on here (I have a list of ~30!) where QoS software, unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
Zach_R
  • 4.13K
  • 137
  • 286
Message 3 of 5
Hi @smartie-02,
I'm really sorry to hear you're having some connection speed issues lately. Are these ongoing today? I can see that @jbrennand has also offered some advice on this. Has that helped at all?
Zach - Forum Team
smartie-02
Message 4 of 5
Will try some of the resolutions suggested next week but in the meantime logged the problem via phone and monitoring speed.
David_Bn
  • 8.54K
  • 359
  • 664
Message 5 of 5
Good Morning @smartie-02,
Have you been able to run the speed test with the hub in modem mode as advised by @jbrennand last week?
Kindest regards,
David_Bn
