  • 167
  • 26
Up to speed
Slow speed after upgrade
ive just upgraded from M200 to M350, and this morning I’m only getting just over 1mbs using cat 6 directly into my PC.
not had an issue with speed before the upgrade
regards
I am not a white Hat Hacker, nor a Black Hat Hacker, more 50 shades of Grey
  • 21
Re: Slow speed after upgrade
Good morning,
can you confirm for me what modem equipment you are running? Is it a Super Hub 3?
  • 89
  • 20
  • 31
Out of interest, most new smartphones will run the 350 wirelessly with a speedtest app. Have you tried this to get an idea of multiple test results?
  • 14.81K
  • 1.16K
  • 3.46K
@HUGH_EFFO wrote:
regards
not sure what the other 2 posts in the thread are about - confusing at best
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream - also post the config page
if its an earlier hub button is top right
its worth trying a reboot and/or a reset of the hub to see if that sorts it
____________________
Tony
