Slow speed after upgrade to M500
prosys
Hi all,
Upgraded to M500 couple of days ago after being on 100 and struggling with utilization. Barely getting 200MBits/sec.
Will post router stats below
7 REPLIES 7
Tested by wire?
prosys
203000000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
12030000004.638256 qam9
22110000004.538256 qam10
32190000004.538256 qam11
42270000004.538256 qam12
52350000004.638256 qam13
62430000004.538256 qam14
72510000004.538256 qam15
82590000004.338256 qam16
9267000000438256 qam17
102750000003.438256 qam18
11283000000338256 qam19
122910000003.438256 qam20
132990000004.138256 qam21
143070000004.638256 qam22
153150000004.938256 qam23
16323000000538256 qam24
173310000004.938256 qam25
183710000005.838256 qam26
193790000005.638256 qam27
203870000005.538256 qam28
213950000005.838256 qam29
22403000000638256 qam30
234110000006.138256 qam31
244190000005.938256 qam32
1Locked38.61800
2Locked38.61510
3Locked38.91290
4Locked38.61170
5Locked38.61200
6Locked38.9780
7Locked38.6580
8Locked38.92340
9Locked38.9410
10Locked38.6770
11Locked38.9880
12Locked38.61430
13Locked38.6670
14Locked38.9520
15Locked38.9830
16Locked38.6380
17Locked38.6350
18Locked38.9280
19Locked38.91550
20Locked38.9990
21Locked38.9350
22Locked38.6290
23Locked38.9310
24Locked38.9290
Yeah tested using CAT6 on both work and personal laptop and tested on 5Ghz on IPhone close to the router
prosys
14620000043512064 qam1
22580000042512064 qam4
33940000042.8512064 qam2
43260000042.3512064 qam3
1ATDMA0020
2ATDMA0010
3ATDMA0000
4ATDMA0000
prosys
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053-b.cm
SFID
33220
Max Traffic Rate
575000000
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
33219
Max Traffic Rate
38520000
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
prosys
Time
Priority
Description
11/10/2021 22:54:20
critical
11/10/2021 16:59:25
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2021 03:57:23
critical
08/10/2021 14:38:46
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:41
critical
07/10/2021 21:44:23
Error
04/10/2021 18:36:25
critical
04/10/2021 11:05:23
notice
04/10/2021 11:04:47
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/10/2021 08:18:8
Error
30/09/2021 21:18:14
critical
30/09/2021 20:18:7
Error
28/09/2021 12:51:50
critical
24/09/2021 19:25:36
Error
24/09/2021 19:25:34
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2021 16:42:5
critical
19/09/2021 23:55:35
Error
17/09/2021 01:32:13
critical
16/09/2021 11:55:35
Error
14/09/2021 07:35:48
critical
Natalie_L
Hi prosys,
Thank you for reaching out to us here on the Community.
I am very sorry to hear you have been experiencing some issues with the service since upgrading.
I have taken a look at the data and nothing is jumping out at me to suggest there is an issue with the power levels.
Are you using a BQM (Broadband Quality Monitor) on the service? If so, are you able to post a link to this so that we may take a look?
Nat
